Water leaking... #908085 09/30/08 12:44 PM
sixpacktr Offline OP
I have a quick question. I have a 98 F150 Supercab which I bought a couple of weeks ago. I noticed that anytime I turn on the inside air (not even the a/c or max a/c, but anything at all) I get some water leakage afterwards. Yesterday I heard it dripping on something hot (I'm assuming exhaust manis, but it could have been the exhaust pipe or engine itself...) and noticed some water on the ground. My question: does the a/c run no matter what when you turn on the inside air, even if it is the defrost or panel/floor? If so, I won't worry too much about it. I drove this morning without the air on and didn't notice any noise as I got out, but will check again on the way home today.
Any help appriciated.
98 Ford F150 XLT
68 Triumph TR250
When looking for a reason as to why things go wrong, never rule out sheer stupidity...
Re: Water leaking... [Re: sixpacktr] #908086 09/30/08 08:21 PM
Our 97 Taurus wagon would run the AC pump in any fan position, fresh air, defroster, all...
Re: Water leaking... [Re: rxinhed] #908087 10/01/08 07:00 PM
93montero_sr Offline
Pressurize the cooling system to raise the boiling boint and look for leaks. Could be a pin size hole dripping (normally at idle or after turning the car off)and then the faster you go could be sraying a tad towards the motor witch would hit the header and smoke. Check the upper and lower radiator hose for leaks.
93 montero sr 3 inch body lift 31x11.50 super swamper ltb, 2 8inch 130 watt pro comp off road lights, 2 55w lights on the rear bumper, rear air locker, magnaflow exhaust muffler,superwinch manual hubs,15x8 black rock crawlers (steel)
PHP: 7.4.33 Page Time: 0.043s Queries: 15 (0.017s) Memory: 0.5934 MB (Peak: 0.6466 MB) Data Comp: Off Server Time: 2026-06-10 01:59:20 UTC
