Locate a Fuel Tank
#908252
10/02/08 12:23 AM
After going through virtually all the parts sites recommended here on the forum, I can't seem to locate one of the 13.7 gallon fuel tanks for my short bed truck. In many cases, they show only one part number and don't even list the tank size. My short bed truck came with either a 14 or 17 gallon tank (52L or 65L) and I have the 14. Anybody know where I can purchase a new tank? Note that the friendly, helpful staff at the local National Tire & Battery is footing the bill since they decided to raise my truck with the shop lift with one of the arms directly under my fuel tank. <img src="/forums/images/graemlins/angry.gif" alt="" />
Richard S. 88 Toy 4x4 Truck, 22RE, 3"BL, 5-Speed, Muds Proud to be an American. Blessed to be a Texan!
Re: Locate a Fuel Tank
[Re: Richards19884x4]
#908254
10/02/08 12:39 AM
$259 at 1sttoyotaparts.com
I'd post a pic of my screenshot, but FTP is broke at work.
(1988 Toyota
OEM parts --> Fuel System --> Fuel Supply --> Fuel Tank)
[Re: Staceman]
#908255
10/02/08 12:41 AM
Looks like $360 for the bigger one.
[Re: Staceman]
#908256
10/02/08 12:51 AM
Thanks for the info, guys. I was unaware that the bigger tank would fit. As a side note, when I tried the toyoDIY parts lookup site, it ONLY shows the 65L tank, but the OE number doesn't match the numbers at a couple of the parts sites.
Now, does going to the 17 gallon tank mean I can still use my existing float gage and pump assy (i.e., will it fit the larger tank)?
Much obliged for the quick responses!
#908257
10/02/08 02:25 AM
Not sure on the float or the pump bracket. It may need to have a taller bracket added onto the pump to sit at the bottom of the tank.
[Re: 4Crawler]
#908258
10/02/08 02:35 AM
Not sure on the float or the pump bracket. It may need to have a taller bracket added onto the pump to sit at the bottom of the tank. Pump bracket for the larger tank is longer. You could use the shorter one and have a larger reserve. <img src="/forums/images/graemlins/smile.gif" alt="" />
1985 SR5 4Runner eLocked with Carter Lock 4.7:1 single case Davez Offroad twin stick
[Re: toyrunner]
#908259
10/02/08 03:18 AM
Pump bracket for the larger tank is longer. You could use the shorter one and have a larger reserve. <img src="/forums/images/graemlins/smile.gif" alt="" /> Hmmmmm.... Seems like that reserve may only be available while going around a corner really fast if the pump won't reach it! <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
#908260
10/02/08 05:19 AM
Keep in mind that your gauge may not read correctly too - I'm not sure about this. I DO know that when I swapped my gauge cluster in my non-SR5 4Runner for the SR5 one, it changed; my guage now goes all the way to the botto, and stays there for another 1/4-ish of a tannk before the light comes on and it's actually empty. I'm guessing this is b/c it's calibrated for a smaller tank (I must have the 17 gal)
Question Reality. ----------------------------- '89 Rnr DLX "SR4.5", 32s w/ 5.29 locked f/r blah blah
#908261
10/02/08 04:58 PM
I bought my new tank from these guys Discount Gas Tanks It looks like the price was up to near $200 for a while but now they are offering it at $120!!! ![[Linked Image]](http://discountgastanks.com/search/images/TO7C.jpg)
'89 4runner SR5, 3.0, auto (fun) '93 xtra cab, dlx,3.0, 5spd (work truck)
