fuel injectors #908384 10/03/08 04:04 PM
binx Offline OP
I picked up some new connectors for my nippon denso injectors on my 94 2.6l (male and female). they looked exactly the same, but apparently they are not <img src="/forums/images/graemlins/angry.gif" alt="" /> the insides dont match up. Is there some kind of special connector for my injectors and if so where do i find them? thanks
2000 amigo ironman, 4" suspension 1" body lift on 33's with 4.77 gears, tera lows, and no-slip locker.
Re: fuel injectors [Re: binx] #908385 10/03/08 05:26 PM
Van Offline
Do you mean the check valves when you say "connectors"?
Go here... http://www.myisuzuparts.com/
and use the '94 pickup as your platform... use the "parts" catalog... engine... under "Assembly"... vaporizer, then pick your vehicle option 4ZE1.
If you find the part #, then go to... http://isuzu.stcharlesauto.com/Department-Parts.aspx
I would suggest Jerry Lemond also, but I'm pretty sure he's on vacation right now.
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
PHP: 7.4.33 Page Time: 0.473s Queries: 15 (0.004s) Memory: 0.5874 MB (Peak: 0.6354 MB) Data Comp: Off Server Time: 2026-07-13 09:20:08 UTC
