Page 2 of 5 1 2 3 4 5
Re: Canada; slightly OT [Re: TOASTY] #908409 10/26/08 05:04 PM
PHIL_ Offline
Okay Toastado, Eric (mitsulvr) did some checking for you, and journeyman welders start off with $38/hr. If you have your B-pressure certificate, the going rate is $50+. Also, I have your resume, gonna try to go through it today for you. Do you have access MS office?
Re: Canada; slightly OT [Re: PHIL_] #908410 10/26/08 07:02 PM
TOASTY Offline OP
I have Openoffice (I am a Linux user) but i can read MS and save as MS file types. I have two certs coming next month but they are CAT specific. So $38/hr is that good enough for a small family to live off of?
Re: Canada; slightly OT [Re: TOASTY] #908411 10/26/08 08:44 PM
torquemonster Offline
Journeyman welders with the B-pressure ticket can pretty much make as much as they want. if you run your own welding truck you can make upwards of $150/hr as a contractor
Re: Canada; slightly OT [Re: torquemonster] #908412 10/27/08 01:53 AM
Mitsulvr Offline
I would say you could live well with that kind of income.
Eric Wegerich
89 Montero as chopped as can be. Now with 5.29's
Re: Canada; slightly OT [Re: Mitsulvr] #908413 10/27/08 05:26 AM
the oilfield is going to be real busy this winter too...so perfect time to get your butt up here and burn some rod
Re: Canada; slightly OT [Re: torquemonster] #908414 10/27/08 06:13 AM
I
IggyB Offline
$38 an hour is roughly $80K per year.
24 pay periods per year will give you $3300 gross per paycheck.
You will pay $1002 in taxes. $537 federal, $252 provincial, $156 in pension plan and $57 in employment insurance.
Which will leave you $2298 every 2 weeks.
And don't forget, houses are still over $350K for a 2 storey 2 car garage.
Re: Canada; slightly OT [Re: IggyB] #908415 10/27/08 09:33 PM
PartyTruck Offline
I like those numbers, maybe I'd move south since everything is pretty much going down the crapshoot up here. The only light at the end of the tunnel is that it's started snowing and Saturday night was a pleasant drive in a blizzard in the middle of nowhere with 4psi in the tires and the heater set just so. <img src="/forums/images/graemlins/kewl.gif" alt="" />
How much does an electrician make over there and is anyone of you bunch man enough to follow me into the white. <img src="/forums/images/graemlins/nana.gif" alt="" />
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: Canada; slightly OT [Re: PartyTruck] #908416 10/28/08 07:46 AM
TOASTY Offline OP
I've got heated seats which i'll need considering i rarely see temps below 50 degrees, but once a year i do a high mountian camping trip and the lowest it's gotten was -7 at daybreak.
I'll need some sweaters and long undies <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Canada; slightly OT [Re: TOASTY] #908417 10/28/08 08:09 AM
kewlynx Offline
You'll need some bunny boots and carhartts or refridgerwear too.
**ubi apis- ibi salus**
Re: Canada; slightly OT [Re: PartyTruck] #908418 10/29/08 03:30 AM
Mitsulvr Offline
Journeyman wage is around 35 for an electrician right now in Alberta. Its a pretty good gig here to. tons of work everyone is hiring and there is not nearly enough skilled labor here. That goes for welders too. I know my company is hiring right now.
http://www.tradesecrets.gov.ab.ca/index.html?page=trades_occupations.asp
My company
http://www.conceptgroup.ca/welcome/index.htm <img src="/forums/images/graemlins/ignore.gif" alt="" />
Hope this helps guys.
Eric Wegerich
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6425 MB (Peak: 0.7670 MB) Data Comp: Off Server Time: 2026-06-05 00:31:59 UTC
