whats does it mean when... #908494 10/04/08 12:14 AM
91monterov6 Offline OP
when i go into reverse from park or if i go into drive from park it kind of slams into gear and the rear drops, if in reverse the rear goes up, any ideas?
Re: whats does it mean when... [Re: 91monterov6] #908495 10/04/08 12:27 AM
bOURGE Offline
Bad u-joint?
1995 Montero SR
1999 Montero
1974 Ford Bronco
Re: whats does it mean when... [Re: bOURGE] #908496 10/04/08 01:26 AM
Happy Birthday hazy_daze Offline
Bad u-joint?
x2. Check em and replace as needed. Always replace in pairs, though. Just makes sense <img src="/forums/images/graemlins/kewl.gif" alt="" />
BTW, the Precision P/N is 450. ~$25 each.
Re: whats does it mean when... [Re: hazy_daze] #908497 10/04/08 03:08 AM
How about control arm bushings?
Re: whats does it mean when... [Re: rxinhed] #908498 10/04/08 04:47 AM
52degrees Offline
High idle.
KG6VNX
Re: whats does it mean when... [Re: 52degrees] #908499 10/04/08 05:29 AM
motero Offline
Broken trailing arm.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: whats does it mean when... [Re: motero] #908500 10/04/08 05:46 AM
mxmikie Offline
trans mount
Re: whats does it mean when... [Re: mxmikie] #908501 10/04/08 06:57 AM
Chris_J Offline
Leaky Tire. Everyone lets take a guess whats next? I'd say head gasket.
Re: whats does it mean when... [Re: Chris_J] #908502 10/04/08 07:00 AM
trailing arm is fine, rear coild are fine, i havent checked the u joint, its set for almost a year, im going to throw it on bricks and check the transfer case bushing.
i'll also check for a bad u joint, what would i look for on them?
Re: whats does it mean when... [Re: 91monterov6] #908503 10/04/08 07:43 AM
got 2 more quick questions, its been more than six months since i tore my dash apart trying to fix my blower motor.
on the center console that holds the radio/clock/cigarette lighter i have a wire coming off the consoles harness and i cant figure where it goes, im up now trying to find it in the electrical manual, its got 3 prongs, 1 verticle red, 1 virticle black, 1 horizontal red with black stripe
(is located on top of the previous two)
and i have a question as to where would be a good place to tap into the electrical to add a second cigarette lighter.
i was thinking of just wiring the new one up to the harness that feeds the stock lighter, and adding a switch to turn power off and on.
i bought a switch and an inline fuse, im planning to use said lighter plug to power a cheap little fan(to keep my doggies in back cool) and the switch it to shut it off without fiddling with the plug.
im kind of going all or nothing with this post lol
last one.... i promise (for this post)
where would be a good place to tap into the power to run a cobra 18wx st2. is there an easy place in the firewall that i could run a wire through? or a wire somewhere i can tap into, i have a filter i can install to clean up the power a bit.
if theres an easy access place on the firewall where i dont have to drill or cut (hey im in wv, i got primitive tools lol) that would be great and i would just run my CB and lighter plug from that, i am within a week of getting my monty inspected and after i fix this ill post pics of what i did.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6370 MB (Peak: 0.7593 MB) Data Comp: Off Server Time: 2026-06-23 23:16:49 UTC
