transfer case options #908603 10/05/08 05:02 AM
91monterov6 Offline OP
would the awd/4wd transfer case from a 1992 montero fit a 1991 montero?
i think it would be nice to have AWD for the snow lol
Re: transfer case options [Re: 91monterov6] #908604 10/05/08 06:13 AM
justice Offline
should fit with the tailhousing from the 92. keep in mind you'll need custom driveshafts and probably cut a new hole on the floor since the shifter is on the opposite side on the gen2.
Re: transfer case options [Re: justice] #908605 10/05/08 06:40 AM
PHIL_ Offline
Dunno about the LHD North American units, but the Japanese Domestic Market models have the t-case on the left of the shifter in the 5sp, and to the right of the shifter in the auto... is it on the same side in both versions in the NA Montero?
Active-trac/Superselect is the single biggest improvement of the genII over the genI, IMHO.
Re: transfer case options [Re: PHIL_] #908606 10/05/08 04:16 PM
justice Offline
On my 89 and jon's 90 autos, the t-case shifter is on the right of the transmission selector and on my 95 auto its on the left.
Re: transfer case options [Re: justice] #908607 11/26/08 12:13 AM
jfarsang Offline
Aside from routing the shift linkage, re-do driveshaft, would it be a direct swap ?
Really looking at this option for an oldie Montero.
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on
89 Montero - Project
92 Pajero Exceed - Gone to a good home
92 Delica Chamonix - Gone to a good home
Re: transfer case options [Re: jfarsang] #908608 11/27/08 08:08 PM
jfarsang Offline
No one's done a GenI to GenII xcase swap ?
Re: transfer case options [Re: jfarsang] #908609 11/27/08 08:36 PM
justice Offline
No one on this board has done it. If your serious about this swap, get the active trac case out of a 93/93 along with the transmission tailhousing and you should be good to go. You'll have to figure out how to get the speedo to work. The gen 2 uses a magnetic pulse input. The function of the case is controlled by the shifted lever. The switches for idicator lights will not be needed for the case to function.
Re: transfer case options [Re: justice] #908610 11/27/08 08:49 PM
jfarsang Offline
Speedo didn't cross my mind.
Thnx.
I could always swap out the speed/gauge cluster and grab the 4wd control unit box behind the cd deck.
Surprised no one's tried/done it.
Having the awd up north is great on icy/snowy roads.
Miss that on my 89
A small PDF on the active trac
http://www.rsgear.com/articles/1997_11.pdf
Re: transfer case options [Re: jfarsang] #908611 11/27/08 10:54 PM
jfarsang Offline
Are the 5spd and auto xcases the same ?
Re: transfer case options [Re: jfarsang] #908612 11/28/08 05:14 AM
NathanC Offline
Sure. I had a Gen2 active trac bolted up to a Gen1 KM148. I had to modify the Gen2 tailhousing to make it work.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
PHP: 7.4.33 Page Time: 0.129s Queries: 16 (0.004s) Memory: 0.6389 MB (Peak: 0.7623 MB) Data Comp: Off Server Time: 2026-06-06 15:46:11 UTC
