Re: ZUK-Coils ultimate test.....Passed.
[Re: matts]
#909066
10/14/08 03:59 PM
There is a potential for the draglink or pitman hitting the leafpack on compression...but that can be avoided by using a straight pitman arm and proper positioning of the box. I just did one for a buddy last weekend and I'll post some pics here soon. As you reminded me, Stace, it was a royal PITA drilling those 2 one inch holes through the frame....I actually chose to torch those 2 holes and it was still a pain. Welding out of position was no joy either <img src="/forums/images/graemlins/zombie.gif" alt="" />
PS---the owner of the truck is amazed at the improvement in steering....it steers easier and much less steering slop. Less bump steer also. He noticed the nose dive.
[Re: ZUK]
#909067
10/14/08 04:24 PM
Where do you source a straight pitman arm?
'89 4runner SR5, 3.0, auto (fun) '93 xtra cab, dlx,3.0, 5spd (work truck)
[Re: matts]
#909068
10/14/08 09:43 PM
[Re: ZUK]
#909069
10/15/08 02:20 AM
Does this flat pitman arm make easier to run Hi-Steer crossover steering setups, like Marlin's, with little (or none) spring lift? Or is there still a leaf spring interference problem that I recall hearing about. -- Matt
[Re: matts]
#909070
10/15/08 05:39 AM
I imagine you could cut off the back end of the driver's side steering knuckle arm after this crossover upgrade. -- Matt
[Re: matts]
#909071
10/15/08 01:40 PM
[Re: ZUK]
#909072
10/15/08 04:31 PM
This should be made into a tech article, or at least a thread unto itself.
Did you end up not re-using the torque arm? -- Matt
[Re: matts]
#909073
10/15/08 05:19 PM
Torque rod was left off...it looked like it might hit the draglink with full compression on the driver side. I thought they were left off anyways with cross-over conversions, in general.
[Re: OOP'S]
#909074
10/15/08 06:01 PM
Aqualu Industries Inc. in Kelowna, British Columbia use to make a dropped forged arm like that. I was just on their page and did not see them offered anymore.
I used to make arms like that about 12 years ago same basic principle just made a bit different. I was going to use one on mine when I did the SAS 12 years ago but Marlin came out with a high steer so I went with it instead. I'll be darn....they still do. But the $439 price tag is a bit out of line <img src="/forums/images/graemlins/scared.gif" alt="" /> I made 2 of them up.... installed one on the above truck and gave him the other as a spare. http://www.aqualu.com/aqualu_industries_incorporated_009.htm![[Linked Image]](http://img.photobucket.com/albums/v221/kenfrancisco/steeringYarm.jpg)
[Re: ZUK]
#909075
10/16/08 02:27 AM
At over $400.00 I hope that they are forged or carved from a billet. -- Matt
