Page 2 of 5 1 2 3 4 5
Re: 89 Raider V6 [Re: justice] #909374 10/10/08 07:24 PM
joe0403 Offline
Sh!t can the spacers. Shocks, put some KYB's on it.
Y'all are stuck on KBY's.
91 Montero, Stock as white bread.
Re: 89 Raider V6 [Re: joe0403] #909375 10/10/08 07:58 PM
hazy_daze Offline
They're great shocks, as are Bilsteins.
Re: 89 Raider V6 [Re: hazy_daze] #909376 10/10/08 08:38 PM
KrzyDav Offline
OME 910 rear spring or Gen 2 rear springs , KYB shocks on rear , at least,,,Tortion bar crank---with Gen 2 upper front control arms to correct Camber.
dave h.
Re: 89 Raider V6 [Re: hazy_daze] #909377 10/10/08 08:41 PM
KrzyDav Offline
I have ~1 1/4" spacers on mine to even out with the SR axle.
Gotta picture of that spacer on an SR rear end.
Is this to correct driveshaft angle???
dave h.
Re: 89 Raider V6 [Re: KrzyDav] #909378 10/10/08 09:45 PM
hazy_daze Offline
No, the spacers are on the front only. It's to correct the width difference in the SR rear axle and the OE open small.
Re: 89 Raider V6 [Re: hazy_daze] #909379 10/10/08 10:51 PM
Happy Birthday Chris_J Offline
Never heard of these shocks you call KBY's <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: 89 Raider V6 [Re: Chris_J] #909380 10/10/08 11:21 PM
PA_JERO Offline
ok 1st off don't get the gen 2 coils and don't us the gen 2 upper control arms, unless you want your coils to fall out (and yes gen 1 V6's have coils) and if you want to snap tie rods on your steering. Just crank your torsion bars and remove shims from the upper control arm shaft and use gen 1 LWB coils in your rear to lift it, that will give you 1" and a half of lift. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 89 Raider V6 [Re: PA_JERO] #909381 10/10/08 11:42 PM
hazy_daze Offline
ok 1st off don't get the gen 2 coils, unless you want your coils to fall out (and yes gen 1 V6's have coils)
I have GenII coils, and mine haven't fallen out. Maybe I'm special.
GenI tie rods are weak, everybody knows this. That's why I carry a set of spares. Tie rods, idler arm, and ball joints.
Why not let the alignment shop do this?
Re: 89 Raider V6 [Re: hazy_daze] #909382 10/11/08 12:09 AM
Grasscat Offline
I don't know if your special or not <img src="/forums/images/graemlins/smile.gif" alt="" />, but you have a Gen II SR rear axle in you truck, do you not?
Michael j
TreadLightly! Trainer
Re: 89 Raider V6 [Re: joe0403] #909383 10/11/08 12:24 AM
I.E. we stick with what's cheap and works. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6449 MB (Peak: 0.7544 MB) Data Comp: Off Server Time: 2026-06-21 17:50:44 UTC
