whats is the minum body lift needed for 302 install 81 pickup
#910411
10/12/08 01:06 PM
whats the minum body lift needed for 302 install 81 pickup
Lots of time not enough money
Re: whats is the minum body lift needed for 302 install 81 pickup
[Re: zachwrenchsr]
#910412
10/12/08 04:36 PM
There are too many factors to say. Depends on how much front lift you have, what trans/transfer you are using, what motor mounts you are using, what oil pan you are using, etc.
Don't let a body lift determine your setup. Get what parts you want and set the engine in place, and if you have to add a body lift, then do so.
[Re: Adam F]
#910413
10/12/08 09:53 PM
And, if the time comes and you must get a lift, 4Crawler Offroad can make you one the exact height you want (e.g.,1.5" or whatever) so it's a good match for your needs, or you could also make your own via the info on his page.
Question Reality. ----------------------------- '89 Rnr DLX "SR4.5", 32s w/ 5.29 locked f/r blah blah
[Re: zachwrenchsr]
#910414
10/14/08 03:40 AM
Every domestic to Toy swap I have seen have all had 3"BL's. I am not sure if it was all needed, but given the size differences, I think a 3" would be your best choice, and any extra clearance you have will be a bonus.
