yj stock limited slip. #910939 10/15/08 05:06 AM
the_other_guy Offline OP
So today i discovered my yj has a limited slip. Apparently it is stock because the dude who owned it b4 me knew nothing of cars (which is why it just sat for 4 years after not passing smog.)
anyone know anything about a stock posi on a 94 yj?
are they any good?
Your road to glory will be rocky, but fulfilling.
- Panda Express fortune cookie
94 YJ. no lift...YET
Re: yj stock limited slip. [Re: the_other_guy] #910940 10/15/08 04:38 PM
BigJim Offline
Pretty reliable posi lockers. If the owner wasn't much into offroading the chances are it is still in great shape. For my uses I prefer posi's to aftermarket lockers..
Re: yj stock limited slip. [Re: the_other_guy] #910941 10/22/08 04:30 PM
SkibumMt20 Offline
make sure you use possi additive
89 YJ DD
87 YJ 350 TBI, SM465, NP241(eh), SOA w/1.5" springs, 35" MTR, D44 (aussi locker)/14bolt (welded) with 4.88's
Re: yj stock limited slip. [Re: SkibumMt20] #910942 10/22/08 11:43 PM
Thats awesome to hear. So im sure its in tip top shape. So far I have only wheeled it once (before i discovered the posi) and i did notice it did exceedingly well for a stock jeep. (altho no jeep should ever be under estimated)
The oil I put in it was regular gear oil, but on the back it said it works with limited slip diffs. Should I still put in an additive as well? If so, what do you recommend?
Re: yj stock limited slip. [Re: the_other_guy] #910943 10/23/08 01:49 AM
BigJim Offline
Most gear oils today have the additive already in them..
Re: yj stock limited slip. [Re: BigJim] #910944 10/23/08 05:54 AM
ok thats what i figured. Just making sure. Gotta protect the goods. haha
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6086 MB (Peak: 0.6785 MB) Data Comp: Off Server Time: 2026-05-30 01:00:28 UTC
