Experience w/ 34x9.5s...
#911171
10/16/08 02:56 PM
I'd like to go bigger on the meats, and may have a chanceto get a deal on some of the skinny 34x9.5 LTBs. Currently running ~3" lift (BJs, 1" BL, 26mm torsions) so they should clear fine. However I'm kind of curious about general opinions on such a skinny tire. Don't really do big rock crawler, in MD it's more woods trails, brown muck dirt/mud, logs, etc (Rausch Creek). My biggest concern is w/ the total track width; thsi meand I'd be 6" taller than stock but only about, what, 1" wider? How far off ratio can these trucks go before that's a problem?
Question Reality. ----------------------------- '89 Rnr DLX "SR4.5", 32s w/ 5.29 locked f/r blah blah
Re: Experience w/ 34x9.5s...
[Re: RatLabGuy]
#911172
10/16/08 03:45 PM
are you sure they are 9.5 and not the 10.5s like my wife had on her truck.
they were pretty awsome.
[Re: RatLabGuy]
#911173
10/16/08 04:12 PM
Interco is the manufacturer. The size 34 x 9.50 x 15 seems to be from their Narrow Super Swamper category. The LTB model has a tire in size 34 x 10.50 x 15. Some users on this website with experience with the 9.50 size have said that they are prone to coming off the rim in rough terrain. You mentioned ball joint spacers and torsion bars, so it seems that you have a 1986 or later truck, which has a wider track width than the earlier trucks. However those trucks came from the factory with wheels with more back spacing than the earlier models. If you bought some cheap steel wheels with less back spacing you could gain a couple of inches of track width. You could add to that by installing some 1 - 2" wheel spacers for another 2 - 4" increase in track width. I've always liked the skinny tire look if the wheels are are pushed out to increase the stance. -- Matt LTB http://www.intercotire.com/tires.php?id=7&g=1Narrow S.S. http://www.intercotire.com/tires.php?id=8&g=1
'89 4runner SR5, 3.0, auto (fun) '93 xtra cab, dlx,3.0, 5spd (work truck)
[Re: matts]
#911174
10/16/08 04:25 PM
I'm currently running a set of 34/10.5/r15 LTBs on my truck. I run them in mud, since that is all I have for terrain around here. They work great offroad, tons of tracton. Pull better than BFG muds/radial TSL swampers/mud kings/thornbirds that I have run in the past. Did I just admit to having thornbirds? <img src="/forums/images/graemlins/zombie.gif" alt="" />
They ride ok on the street under 55mph, anything above that and it's like riding in a paint mixer. I had 16/35/r15 boggers unbalanced on a 15x14 steel wheel and they rode better than the balanced LTBs. The boggers did pull harder, but I couldn't turn them as easy in the muck so the LTB's actually get me further.
Fur clog in the sausage grinder
[Re: RatLabGuy]
#911175
10/16/08 05:08 PM
I always prefer a narrower tire for wheeling, especially in the conditions on my side of the smokies...better traction in mud and mud holes. Wider tires are ok, but have a disadvantage in deep mud. Also, unless there is good side tread, have a disadvantage in deep ruts too. Alot of the trails were made long ago with mostly jeep types with a narrower track width anyway, so I wouldn't worry so much about it, but I do like the slightly wider stance and the narrow tire look as well.
[Re: krb90]
#911176
10/16/08 06:55 PM
One issue I have heard about the old 9.50 TSLs is you need to run them on a narrow rim, like 6" or less (5" or 5.5" is better) to help keep them from popping beads when aired down.
When I run my 33x9.50 BFGs, I add some wheel spacers to push the track width out as wide as I can get it.
[Re: 4Crawler]
#911177
10/17/08 03:39 AM
Sorry about the confusion on the model; What I really want is the 34x10.5 LTBs, I guess that's just what I had on my mind (had been drooling through the website all afternoon). Yes I assume these are the skinny Swampers, they just happen to be available used... I'm trying to avoid buying a new set since it will take me eons to wear them out anyway.
Hadn't thought about spacers to widen the stance. Wheels they'll go on are 7", looks like 3.5" backspacing. Oh, and yes it's an IFS truck ('89)
[Re: RatLabGuy]
#911178
10/18/08 04:20 AM
To chime in <img src="/forums/images/graemlins/smile.gif" alt="" /> I have the 33"x13.5x15 LTB's and I am VERY pleased with the performance.... Now for the the 34"x9.5x15 (pizza cutters) I did wheel with a J**P <img src="/forums/images/graemlins/ignore.gif" alt="" /> CJ last month that was running them, he didnt have any issues with the tires, it was mostly rock / dirt.. I wanna say a 8" wide wheel Even the 34x10.5's I wouldnt go any wider than a 8" wide wheel - you dont wanna pop off the bead.. If you want pics <img src="/forums/images/graemlins/smile.gif" alt="" /> Linky to my Runner - 33x13.5 Linky to CJ - 34x9.5
[Re: trcdrunner]
#911179
10/19/08 02:30 AM
When I lived in Western Colorado I learned quickly that the best tire for trail running was a pizza cutter. Where I lived the terrain was a mixture of rocks and soil with a lot of clay in it. The soil is also pretty thin, so when it rains the top few inches (maybe more than a few) turns to mud that is more like grease than anything else. The secret to making your way from point A to point B was to dig down to the hard ground for traction. Wider tires had too much flotation, so they would just ride up on top of the "grease", where they couldn't get any bite. I'm sure tire technology has come a long way since those days resulting in wide tires that can get much more traction, but the other problem is that many of the mountain trails are on a side hill which pitches your vehicle way over to the side. If you are floating on top of the grease in that situation, you're sliding off the side of the trail, which is usually really dangerous if not down right inconvenient. Of course this may be old-school thinking, cause I am kinda old-school myself. So when I move back out there I'm going to think seriously about a trail rig with 9.50's on 7" wheels with 2 1/2" of custom back-spacing from Rocky Road Outfitters and Marlin Crawler's billet wheel spacers of maybe about 1 1/2". -- Matt
[Re: matts]
#911180
10/20/08 08:11 PM
When I lived in Western Colorado I learned quickly that the best tire for trail running was a pizza cutter. Where I lived the terrain was a mixture of rocks and soil with a lot of clay in it. The soil is also pretty thin, so when it rains the top few inches (maybe more than a few) turns to mud that is more like grease than anything else. The secret to making your way from point A to point B was to dig down to the hard ground for traction. Wider tires had too much flotation, so they would just ride up on top of the "grease", where they couldn't get any bite. I'm sure tire technology has come a long way since those days resulting in wide tires that can get much more traction, but the other problem is that many of the mountain trails are on a side hill which pitches your vehicle way over to the side. If you are floating on top of the grease in that situation, you're sliding off the side of the trail, which is usually really dangerous if not down right inconvenient. Of course this may be old-school thinking, cause I am kinda old-school myself. So when I move back out there I'm going to think seriously about a trail rig with 9.50's on 7" wheels with 2 1/2" of custom back-spacing from Rocky Road Outfitters and Marlin Crawler's billet wheel spacers of maybe about 1 1/2". -- Matt i think that is generally the way it is anywhere you are going to be in mud. Wider tires probably help in rock climbing, which I don't ever really do alot of. Tractor tires, swamp buggy tires are all tall and thin for a reason.
