Re: Gen 1 V6 V5MT1 Bellhousing swap
[Re: yankneck696]
#911512
10/22/08 10:55 PM
I have an AutoCad drawing of the mounting face that I drew a number of years ago that is hiding somewhere. I will get the other measurements to you soon.
[Re: OldColt]
#911513
10/23/08 12:11 AM
Sweet !!! I thank you greatly. With the autocad, how would I view it?
Ed
Yankneck = Yankee ingenuity with Redneck stupidity. "How can I break it better?" 89 Raider 3.0 w/ 31's for now
[Re: yankneck696]
#911514
10/23/08 01:12 AM
Download a freeware .dwg viewer.
[Re: fasteddy]
#911515
10/23/08 11:13 AM
[Re: yankneck696]
#911516
10/23/08 01:09 PM
The bell is 7" tall. It does not have a simple bore in it as an American bellhousing does. This one is the front of the gearbox so it is machined as the bearing retainer for both shafts and has the TO bearing guide tube integral to the casting. My drawing of the mounting face is still hiding.
[Re: OldColt]
#911517
10/23/08 10:44 PM
Well, if it's the bearing retainer, I guess it's out of the question... I do have a friend with a Yota setup I can get & can swap out alot of bells with that, or just use tha Isuzu setup...\
Thanks alot...
Ed
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6165 MB (Peak: 0.6857 MB) Data Comp: Off Server Time: 2026-06-10 04:16:52 UTCValid HTML 5 and Valid CSS
