258 burnt valve
#911788
10/20/08 08:47 PM
My jeep is acting like it's got a burned valve. It runs really rough at idle (missing). I have not pulled the plugs or done a compression check yet but I do have a spare 258 that was rebuilt about 30K ago I was working on (its dissasembled now). If that is the problem, would I be able to stick that head on, with new lifters and pushrods, without any machine work or would that be a bad idea?
80 CJ-7. It runs
Re: 258 burnt valve
[Re: jstritec]
#911789
10/21/08 04:02 AM
Sure that'll work finr.. I betcha 99% of all head millings are useless. A slightly warped head was warped when it was ON THE ENGINE! It gave no problems then and when reinstalled it will torque down tight again. Big Jim <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: 258 burnt valve
[Re: BigJim]
#911790
10/21/08 03:51 PM
Thanks Jim I'm thinking if I pull the head I might as well look into a 4L head swap. Josh
80 CJ-7. It runs
Re: 258 burnt valve
[Re: jstritec]
#911791
10/21/08 04:09 PM
That swap can getcha into a lot of time and trouble.. I think I would pull the offending head and lap a new valve in place (leaving everything else alone) and reinstall it! Then If I wanted an engine with the 4.0 head I'd be building one in my shop to install the complete engine in the future. Big JIm <img src="/forums/images/graemlins/pfft.gif" alt="" />
Re: 258 burnt valve
[Re: BigJim]
#911792
10/21/08 06:46 PM
Jim You're probably right. I mean if it comes down to really upgrading a 258 the best bet would be to just find a pulled 4.0 and stick that in. Josh
80 CJ-7. It runs
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6031 MB (Peak: 0.6673 MB) Data Comp: Off Server Time: 2026-06-01 16:18:00 UTCValid HTML 5 and Valid CSS
