whirring sound
#911986
10/22/08 09:02 AM
it just developed recently as i have this whirring sound coming from the fuel pump of my 4d56t. when i turn on the a/c (idles up to 900rpm) the pitch is higher and louder but when i step on te accelerator past 1k rpm it "seems" like thre is no whirring sound. what could this be?
Re: whirring sound
[Re: Maki]
#911987
10/23/08 05:31 AM
I had a bit of a "whistle" due to an air leak from around the sensor in the intercooler which sits right above the fuel pump.
Re: whirring sound
[Re: Maki]
#911988
10/23/08 08:21 PM
Make sure your belts are tight. I have to tighten my alt. belt every few months otherwise it will do what you describe below 1000 rpm, rev it up and it goes away.
Re: whirring sound
[Re: redbull]
#911989
10/24/08 04:20 AM
I had a bit of a "whistle" due to an air leak from around the sensor in the intercooler which sits right above the fuel pump. sorry im one of the few who doesn;t have intercoole, but i;ve also checked the vacuum lines in that area.. no leaks. thanks for the info
Re: whirring sound
[Re: RuffStuff]
#911990
10/24/08 04:24 AM
Make sure your belts are tight. I have to tighten my alt. belt every few months otherwise it will do what you describe below 1000 rpm, rev it up and it goes away. good idea, i;ve never thought of the the belts as there is no squeal. will check the a/c belt in that area.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6034 MB (Peak: 0.6672 MB) Data Comp: Off Server Time: 2026-06-21 01:52:22 UTCValid HTML 5 and Valid CSS
