31x10.50x15 Tires
#912358
10/24/08 01:40 AM
Will they fit a 1989 Dodge Raider without modification to the stock ride height, fender wells, and will steering be affected. Thanks
Re: 31x10.50x15 Tires
[Re: morgueman]
#912359
10/24/08 01:43 AM
They will fit easily-some guys are running 33's. <img src="/forums/images/graemlins/kewl.gif" alt="" /> There is a write-up on here somewhere regarding fitment.
[Re: morgueman]
#912360
10/24/08 01:44 AM
will they fit what? you should put your vehicle profile in your sig. btw, welcome to the wire.
[Re: morgueman]
#912361
10/24/08 02:13 AM
Can fit 32's w/ only the most minor (1/16-1/8") trimming of your front bumper's rubber end caps. The tires will do it for you if you let them.
Otherwise you may also need a wider rim if the 32's are too wide.
That said, 31's will definitely fit. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#912362
10/24/08 03:35 AM
Easily. As mentioned, you can fit 33x12.5s with simple, minor modification. The key is getting the right rims.
I have a 2" body-lift and a 2" suspension lift and am only running 33x12.5s (waiting for them to wear out). If I'd wanted, I could fit 39s with some rubbage (I've scoped it out). My next set of tars will be 35s. 37s would be more than I care with which to task the axles.
?_________ |_|_|\____\___ l-----[O]≡≡≡≡[O] ()_)()_)-----)_) Stay the Trail!
[Re: CapnCrunch]
#912363
10/24/08 06:07 AM
There was a long thread awhile ago with pics of different rim and tire sizes, anyone know where it went?
Searched and couldn't find it.
1989 Montero 4dr V6 3.0l
[Re: 89montero]
#912364
10/24/08 06:40 AM
With some liberal trimming of the front plastic bumper caps and some hammering inside the fenders you can fit 33x12.5 TSLs (that measure out to 33.7"). So technically in theory you can run 34x10.5 LTBs that measure out to only 33.6". So yes you can run 31x10.5 with no problems, my own set of 31x10.5s have never rubbed even when flexing/stuffing the tires.
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB 88 Raider(Silver):No 2.6/Bad KM145 Parts/Project 88 Montero(Brown):No 2.6,4.88s Parts/Project [b]4X4 STICKERS,SHIRTS,ETC: 4WD Stickers AT COST.[b]
[Re: morgueman]
#912365
10/24/08 04:46 PM
As others mentioned they fit just fine. One other thing to think about is rim width. The stock rims are a bit narrow for 10.5"s and you will get a bit of a bulge on your tread.
I have run them that way but later on opted for a set of wider rims.
Other things to consider is what you have for a drive train. A stock 2.6 with an auto is going to lose a fair amount of pep and fuel economy pulling those taller tires. The stick is not as bad and the V6 should be just fine.
Kevin C
[Re: morgueman]
#912366
10/24/08 05:43 PM
Will they fit a 1989 Dodge Raider without modification to the stock ride height, fender wells, and will steering be affected. Thanks Here you go. BFG All-Terrain T/A KOs in 31x10.50 on 15x8 Ultimate steel rims. ![[Linked Image]](http://i82.photobucket.com/albums/j258/imzadi930/BFG1.jpg) ![[Linked Image]](http://i82.photobucket.com/albums/j258/imzadi930/BFG3.jpg) ![[Linked Image]](http://i82.photobucket.com/albums/j258/imzadi930/BFG2.jpg)
1987 Dodge Raider TSi
...it begins.
[Re: Kevin C]
#912367
10/24/08 05:59 PM
Kevin C
It depends on what kind of rims your putting them on also. I moved from 235/75 on the steel rims to 31x10.5 on the LS Alloys and if anything saw an improvement. I can't speak for the auto, but with the stick and 31s on alloys you won't see any drastic change. On the other hand steel rims are heavier, and you might get some kind of slight loss then.
