trooper bolt question #912518 10/24/08 03:55 PM
rhouser Offline OP
I have a 89 trooper, i am missing on of the bolts that holds the caliper assembly on. I was able to get a 23mm socket on the top one that is still there, can anyone tell me what thread the bolt is and what lenght it is so i can go to hardware store and get a new one?
thanks
Re: trooper bolt question [Re: rhouser] #912519 10/25/08 03:14 AM
JLEMOND Offline
thanks
DONT DO THAT , THAT IS A SPECIAL BOLT AND A HARDWARE STORE BOLT IS VERY RISKY , GO TO A DLR AND ORDER THE CORRECT ONE ,IT COULD SAVE YOUR LIFE, THE CORRECT PT NO IS 894423- 252 0 , IT IS A 14MM DIA X 29 MM SHANK
LENGTH WITH 1.5 MM THREAD PITCH. JERRY
Re: trooper bolt question [Re: JLEMOND] #912520 10/25/08 05:52 AM
lttlbddy Offline
Since dealers are hard to find, you can try St Charles Isuzu - (800) 727-8066. Free shipping!!
A junk yard would be a good source also.
Re: trooper bolt question [Re: lttlbddy] #912521 10/27/08 06:02 PM
rhouser Offline OP
I found it at hardware store, took a couple trips...why order one when the hardware store has them 14MM x 1.5 pitch
Re: trooper bolt question [Re: rhouser] #912522 10/27/08 07:04 PM
BigSwede Offline
Because they aren't the same grade. The Isuzu bolt is stronger.
Serenity now!
Re: trooper bolt question [Re: BigSwede] #912523 10/27/08 07:16 PM
RobG Offline
yea, and I doubt your hardware store carries a metric bolt in grade 10.9 or higher. you'll need to go to a speciality fastener store at a minimum.
running a std hardware store bolt esp on brake components is asking for trouble.
-Rob
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6089 MB (Peak: 0.6787 MB) Data Comp: Off Server Time: 2026-06-12 19:45:42 UTC
