Emergency Brake Light
#912548
10/24/08 09:57 PM
I have a 1995 T100 4x4 SR5 and lately the brake light will light up on the dash and then go off on its own.. I checked the brake to see if it was not released all the way but it was?? Any idea why the light is coming on and going off on its own? Happens every time I drive.. Thanks!
Re: Emergency Brake Light
[Re: toyotakev]
#912549
10/24/08 11:05 PM
Toyota Moderator
Top off your brake fluid. Fluid is slightly low since your brake pads are wearing. Light comes on before it gets as low as the "low" mark in the reservoir.
[Re: ErikB]
#912550
10/25/08 12:14 AM
Erick is dead on. Happened to me. 93T
trafdlo
[Re: toyotakev]
#912551
10/25/08 03:58 AM
Does it fade on or dimly lit? If so, it could be the sensor on top of the reservoir. I ended up unplugging mine as it drove me crazy. <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: BamZipPow]
#912552
10/26/08 12:01 AM
Problem with that is that someof the functions of the truck are inhibited if the sensor is not "inactive". Can't remember if it was ovedrive or AC but, watch out for that/
trafdlo
[Re: wsquaredodie]
#912553
10/26/08 01:06 PM
Thanks for the help.. I will top off the brake fluid today and let you know.. The light is not dim or fade, it just comes on as if the brake is pulled and goes off as if it was released.. Just got back from Louisville last night and didn't have a chance to check these replies but I will top off the brake fluid this morning and report back, thanks again!
[Re: toyotakev]
#912554
10/27/08 09:44 PM
Problem fixed.. you guys are great!
[Re: toyotakev]
#912555
10/28/08 01:40 AM
Cangrats. Was a revelation for me when I did it...
trafdlo
PHP: 7.4.33 Page Time: 2.474s Queries: 15 (0.003s) Memory: 0.6223 MB (Peak: 0.7038 MB) Data Comp: Off Server Time: 2026-06-21 12:39:09 UTCValid HTML 5 and Valid CSS
