Help with lights please... #912793 10/27/08 11:56 AM
MuddRunner Offline OP
I haven't had time to figure out what is wrong, I had to get to work and I figured while I'm here all day I might as well get some other's thoughts...
'92 pickup, 4x4 4 cyl auto.
Started the truck this morning, turned on the lights and they flashed and went out. Just the head lights mind you, the parking lights all work fine. I tried my hi beams, only one side works. So there it is, running lights are fine, no lo beam and only one hi beam...
Todd
'92 Pickup x-cab, 22re, auto.
'50 Ford Tudor Sedan, my new "Hot Rod"
Too much to do, too little time/$$$
Heb. 12.3
Re: Help with lights please... [Re: MuddRunner] #912794 10/27/08 04:33 PM
4Crawler Offline
Bulbs OK? They can and do burn out.
Pull back on the dimmer stick and see what happens? If that works OK (low and high beams on), then might be a problem in the headlight combo switch:
- http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#Headlight_Combo
Otherwise check for voltage at the headlight connector itself:
- http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#VoltageTest
Re: Help with lights please... [Re: 4Crawler] #912795 10/27/08 05:10 PM
[color:"blue"]Pull back on the dimmer stick and see what happens?[/color] If that works OK (low and high beams on), then might be a problem in the headlight combo switch:
[color:"blue"] Just the one HI beam comes on, once the two lo beams flashed when I first turned them on, nothing... [/color]
Heb. 12.3
Re: Help with lights please... [Re: MuddRunner] #912796 10/27/08 06:50 PM
ACES_HI Offline
I would replace both headlights as a first step. They're cheap and its the quickest fix. If that isnt the problem then at least you have new lights. I've had both lights blow at once.
'04 Taco x-cab 3RZ FE stock (daily driver)
'90 x-cab 22RE stock
'82 Hilux 6" lift (ACES HI)
'82 2-Hiluxs' Rally Edition (parts)
'81 Hilux 3" lift (parts/restore)
Re: Help with lights please... [Re: ACES_HI] #912797 10/27/08 11:43 PM
P
philly Offline
you check all fuses? my combo switch went out once.. it made my lows work but when i hit the highs all my lights went out.
PHP: 7.4.33 Page Time: 3.009s Queries: 15 (0.009s) Memory: 0.6079 MB (Peak: 0.6733 MB) Data Comp: Off Server Time: 2026-07-14 12:32:46 UTC
