Re: Buzzing speedo? [Re: Cochese] #912824 10/28/08 05:56 PM
ghostraider Offline
send the speedo to me and i will reset your odom for free.
hmmmmm...maybe i should start a speedo repair/maintenance thread.
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Buzzing speedo? [Re: ghostraider] #912825 10/28/08 06:09 PM
RocLimer Offline
Did you take the link out of your sig? I could have sworn some one in here had a speedo reapir company url link in their sig that I saw last night who was based out of San Jose.
1989 Montero 2-Dr 3.0L V6 15X8 ProComp 97 Series w 30.5x9.5 Cooper M/T's
http://www.cardomain.com/ride/3143932
Re: Buzzing speedo? [Re: RocLimer] #912826 10/28/08 06:37 PM
It's in his profile. Click on his name. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Buzzing speedo? [Re: ghostraider] #912827 12/08/08 04:37 PM
Cochese Offline OP
My parts cluster source fell through on eBay. The buzz is unbearable so I'm going outside to take a whack at lubing the cable. So I should ONLY lube from the tranny side?
I can't lube from the speedo side? And Tri-Flo won't work? I have some white lithium grease handy too...
If this doesn't work and it blows up, I'll be needing to replace the tach AND speedo. <img src="/forums/images/graemlins/smile.gif" alt="" />
1987 Dodge Raider TSi
...it begins.
Re: Buzzing speedo? [Re: Cochese] #912828 12/08/08 05:35 PM
Cochese Offline OP
Well, that didn't take long. I even ran to the store and got cat food to test it out. Buzz is gone. The real test will be tonight when there is 5-10 inches of snow and its cold as fleck.
Thanks braintrust!
Ghost, I may end up sending a tach to you one of these days!
...it begins.
Re: Buzzing speedo? [Re: Cochese] #912829 12/08/08 05:44 PM
ghostraider Offline
the tachometer is unrepairable....i could bench test it for you and if it is bad then i throw it in trash can!
Check the back of tach for Positive 12 volts , good ground and signal form distibutor ( flashing 12 volts).
If your inputs are good: then get a junkyard replacement!
Re: Buzzing speedo? [Re: ghostraider] #912830 12/17/08 06:21 PM
RocLimer Offline
Cochese, what did you end up doing that worked? Was it lithium grease from the transmission side of the cable?
Let me know. My speedo was getting pretty loud this morning and I would hate to break something without trying to fix it first.
Re: Buzzing speedo? [Re: RocLimer] #912831 12/19/08 05:32 PM
ghostraider Offline
just unscrew the cable and housing at the trans and pull the cable out...use any decent grease but not too thick and grease up cable....either it will fix the problem or your speedo is shot!
<img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6327 MB (Peak: 0.7313 MB) Data Comp: Off Server Time: 2026-06-17 13:13:54 UTC
