Re: Gen I SWB 2.6 "V6 upgrade" components? [Re: MontyMcV] #913086 10/30/08 04:42 PM
CwnAnwyn Offline
I'll double check the ones I have on there this weekend. I still have the other cv shafts. I had everything in piles around the garage from both trucks. I was pretty sure I pulled them from Monty pile and not the Raider pile. <img src="/forums/images/graemlins/smile.gif" alt="" /> But I could have grabbed the other ones. <img src="/forums/images/graemlins/smile.gif" alt="" />
Do you think the average stormtrooper knows how to install a toilet main? All they know is killing and white uniforms.
87 Raider TSI
84 K5, 350/700R4,36" TSLs, spooled fr/rr
74 VW Bug- volksrod project
68 VW Fastback, 2L T4 powered
Re: Gen I SWB 2.6 "V6 upgrade" components? [Re: CwnAnwyn] #913087 10/30/08 06:27 PM
Same outboard ends of course. I don't know the spline count between the two. I have an extra set of I4s though and count them, if no one else knows off hand.
Re: Gen I SWB 2.6 "V6 upgrade" components? [Re: MontyMcV] #913088 10/30/08 11:02 PM
KrzyDav Offline
I'm running 2wd Montero sport front calipers on my 89 v6, with the M.S. dust shields. You still have to trim about 1/2 in off the shield to make room for the bottom of the caliper cause the bolt hole are slightly off.
2wds are alot easier and faster to steal parts from, they are newer and not as corroded as the 4wds. The calipers are the same as gen 2 3.0s.
dave h.
Re: Gen I SWB 2.6 "V6 upgrade" components? [Re: Cochese] #913089 10/31/08 02:23 AM
CapnCrunch Offline
Does anyone think P/N's would be a good addition to this thread?
It'd be nice, but I don't have them handy. I'd have to go digging through CAPS and I haven't reinstalled CAPS yet since I rebuilt my PC. If I do anytime soon, I'll see about digging some of it up.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Gen I SWB 2.6 "V6 upgrade" components? [Re: CapnCrunch] #913090 10/31/08 03:59 AM
P/Ns would be handy, but work. Most of this is boneyard stuff I'd say...?
Re: Gen I SWB 2.6 "V6 upgrade" components? [Re: MontyMcV] #913091 10/31/08 04:29 AM
CapnCrunch Offline
True. Of the items I have listed above, everything was 'yard parts except for the bolts/nuts for mounting the UCAs, the brake disks, the calipers, and all the consumables in the front diff (shims, washers, collar, bearings, etc).
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6212 MB (Peak: 0.6911 MB) Data Comp: Off Server Time: 2026-06-21 00:15:49 UTC
