Page 2 of 6 1 2 3 4 5 6
Re: 3 Car seats in a first gen LWB? [Re: cyberbackpacker] #913160 10/29/08 05:23 PM
W
WagonMaster Offline
Thanks again for the info... finding a SWB rear seat and its mounting brackets does sound like the way to go; however, finding them is the problem...
Where are you?
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: 3 Car seats in a first gen LWB? [Re: WagonMaster] #913161 10/29/08 07:22 PM
cyberbackpacker Offline OP
I am in North Central Pennsylvania (Lewisburg, 17837).
And Wagonmaster, there is really a bolt for third row shoulder belts? If so, I am SOLD smile
Do you happen to have any pics of your setup perchance?
Thanks again.
The hunt is now really on in earnest for my first Gen I LWB...
I have been checking craigslist in the driveable areas, and have not seen a SWB or LWB Gen I listed in a couple months...
-cyberbackpacker
WTB: GEN I LWB within 3 hour drive of 17837.
WTB: GEN I SWB rear seat and bracketry.
Re: 3 Car seats in a first gen LWB? [Re: cyberbackpacker] #913162 10/29/08 09:00 PM
W
WagonMaster Offline
Thanks again.
I'm in Seattle: Bit far, I'm afraid. <img src="/forums/images/graemlins/barf.gif" alt="" />
No, there is no bolt for a third row belt. There is a hole where a bolt would be. The hole also exists in the plastic cover panel (and is covered by a plug). If you can weld, you can easily install a belt bolt in that position, then pull the plug out and mount yer belt. Git er done!
Interestingly, a hole in the same 3rd row position also exists in the SWB version.
No pics at this time, sorry.
Re: 3 Car seats in a first gen LWB? [Re: WagonMaster] #913163 10/29/08 09:25 PM
Thanks again...
I meant a place for a bolt to go, so what you said is actually the answer to the question that was in my head smile
-cyberbackpacker
Re: 3 Car seats in a first gen LWB? [Re: cyberbackpacker] #913164 10/29/08 09:40 PM
We did my Bro's LWB a few years ago. Just used the lapbelts though.
Here is an old thread.
Re: 3 Car seats in a first gen LWB? [Re: MontyMcV] #913165 10/29/08 10:18 PM
Thanks MontyMcv!
If one were to have luck in getting matching upholstery, the uninformed would never know they were not OEM.
-cyberbackpacker
Re: 3 Car seats in a first gen LWB? [Re: cyberbackpacker] #913166 10/29/08 10:41 PM
W
WagonMaster Offline
Thanks again...
See, you got me doing it now! <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Let me try again. There is a hole where a NUT would go, that you could bolt the seatbelt to. There is a corrisponding hole in the plastic to allow you to put the bolt into the NUT that would be welded at the spot of the hole.
This also exists in the SWB.
Re: 3 Car seats in a first gen LWB? [Re: WagonMaster] #913167 10/30/08 02:47 PM
I don't think you'll match the interior exactly. Unless maybe a harder to find 89-90 SWB had the same patterns. The earlier years I have seen are not the same as the later LWBs.
My SWB didn't need a nut welded. It was already prepped, like the the way the front seatbelts bolt in up high.
Re: 3 Car seats in a first gen LWB? [Re: MontyMcV] #913168 10/30/08 04:53 PM
W
WagonMaster Offline
Did it have a nut in the "3rd" seat position (even though it's a SWB), or just the 2nd seat position?
Re: 3 Car seats in a first gen LWB? [Re: WagonMaster] #913169 10/30/08 06:24 PM
I would describe it as in an equivalent position relative to the seat placement. IOW, the rear in an SWB is more like the third row area in an LWB. My three-point rears have the high bolt up above the rear window and slightly behind the send row seats. All I had to do was bolt in the belt, the strengthened thread point was already there (behind the cap).
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6429 MB (Peak: 0.7522 MB) Data Comp: Off Server Time: 2026-06-21 17:51:48 UTC
