Page 2 of 3 1 2 3
Re: Gen 1 - Front suspension question - Single POP? [Re: fasteddy] #913375 10/29/08 07:49 PM
RocLimer Offline OP
Thanks guys. I'll take a look tonight when I get off work. I was just looking in the repair manual and couldn't find what you're describing. Is it called something else?
1989 Montero 2-Dr 3.0L V6 15X8 ProComp 97 Series w 30.5x9.5 Cooper M/T's
http://www.cardomain.com/ride/3143932
Re: Gen 1 - Front suspension question - Single POP? [Re: RocLimer] #913376 10/29/08 08:23 PM
The stop bolt is on the front side of the spindle, under the arm where the tie rod attaches. The stop plate is on the lower a arm. The only pic I find is in the front axle section on the spindle disassembly section, and that only show the stop bolt location. I find no image of the stop plate. I swear I saw the lube stuff in the lube/maint. section, but maybe it's in the owner's manual. Way too much stuff in my head...
Re: Gen 1 - Front suspension question - Single POP? [Re: fasteddy] #913377 10/29/08 11:07 PM
Grasscat Offline
Maybe this will help.
Michael j
TreadLightly! Trainer
Re: Gen 1 - Front suspension question - Single POP? [Re: Grasscat] #913378 10/29/08 11:25 PM
sparkem Offline
Steering stop x12
Re: Gen 1 - Front suspension question - Single POP? [Re: sparkem] #913379 10/30/08 04:16 AM
CapnCrunch Offline
Steering stop x12
x24
?_________
|_|_|\____\___
l-----[O]≡≡≡≡[O]
()_)()_)-----)_)
Stay the Trail!
Re: Gen 1 - Front suspension question - Single POP? [Re: CapnCrunch] #913380 10/30/08 02:55 PM
Courtesy of Phil and the Mitsu Tech section of the Wire... Steering grind article
Re: Gen 1 - Front suspension question - Single POP? [Re: MontyMcV] #913381 10/30/08 04:33 PM
RocLimer Offline OP
That was exactly what I was looking for. I wonder if that is a part that can be ordered from a dealer. A small plastic grommet shouldn't be all that expensive and a better repair every so many years rather than months or weeks.
Re: Gen 1 - Front suspension question - Single POP? [Re: RocLimer] #913382 10/30/08 05:54 PM
hazy_daze Offline
A dab of grease every few weeks is usually free coming from the tub I have in the garage....
Re: Gen 1 - Front suspension question - Single POP? [Re: hazy_daze] #913383 10/30/08 10:40 PM
RocLimer Offline OP
I called my local mitsubishi dealer and it a part that is still stocked and costs $8.75 + tax ea. and are special order only.
Re: Gen 1 - Front suspension question - Single POP? [Re: RocLimer] #913384 10/30/08 11:55 PM
For $20 then, I'd first try cutting a piece of hose slightly longer than the stop-bolt. Slip it over the bold and see how long it lasts. That is, if you don't want to do the grease bit. For that matter, how many seconds a year do you spend at full steering lock anyway?
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6414 MB (Peak: 0.7479 MB) Data Comp: Off Server Time: 2026-06-07 05:59:39 UTC
