Gen 1 - Front suspension question
#913365
10/29/08 05:49 PM
I don't think I've come across this problem in the forum anywhere.
When I have the steering cranked over to make a hard left turn I get a metallic pop or grinding sound from the front passenger side axle assembly area. It also happens in lighter turning but when I am making a sudden suspension raise/drop i.e. a large curb sized obstacle (4-6"). I would like to fix this problem if possible before I do any trailing as I would hate to have something break while on the trail.
Any thoughts?
Re: Gen 1 - Front suspension question
[Re: RocLimer]
#913366
10/29/08 06:43 PM
sound like the early signs of a CV joint failing. Are the boots cracked or split? Raise that side up and with the wheel cranked hard over, spin the wheel and listen for the noise while checking the deep folds of the boots for splits. It might not make the noise without being under load,though.
91 Montero LS,3.0L,auto,off road pkg. 89 Trooper S,2.6L,5 spd 07 Dodge Ram 2500 4x4,5.9L Turbodiesel,6spd "Non Vi Sed,Arte"
[Re: DREDnot]
#913367
10/29/08 07:01 PM
I look at the CV boots regularly as I know the problems that can happen if a CV boot isn't repaired quickly. The boots are not cracked and are not/have not leaked any grease since I have owned the truck.
[Re: RocLimer]
#913368
10/29/08 07:12 PM
ball joint perhaps? could also be worn anti sway bar rubber grommets.
Re: Gen 1 - Front suspension question - Single POP?
[Re: RocLimer]
#913369
10/29/08 07:17 PM
Is the noise just a single "POP", or does it continue to grind as you turn?
89 Raider V6, manual, 5.29 gears, ARB front locker
[Re: Quixotic]
#913370
10/29/08 07:25 PM
Sounds more like the steering stops.
[Re: hazy_daze]
#913371
10/29/08 07:29 PM
It's more of a pop. It doesn't continue to grind but will pop again after 5 to 10 feet if I'm making a larger turn and don't back off on the steering. I've check for clearence issues and any sort of rubbing and I don't see anything. It's a pretty loud sound. Is is possible its a tie rod end or something like that?
[Re: RocLimer]
#913372
10/29/08 07:31 PM
The sway bar rubber is good on the bar itself, but is almost gone and cracked through on the bar ends on both sides of the vehicle.
[Re: RocLimer]
#913373
10/29/08 07:41 PM
I think Hazy's got it. Take 2 minutes to put a dab of grease on your steering stops and see if the noise goes away.
1990 Monty LS 3.0 A/T LWB. KYB front shocks, OME rears and coils. 33x10.5 BFG Muds. 5.29, 2.85, RD110, RD46. 2 bouncys. Aisins. Monte Disco swaybar disconnects. GenII t-arms, idler arm, UCA's, V45W front brakes. 2in BL.
[Re: RocLimer]
#913374
10/29/08 07:43 PM
It's the steering stops. When at full steering lock, there's a plate on the (a arm?) and an adjustable bolt stop to limit the steering turn on the spindle(?) that move in relationship to each other as the suspension cycles in the bump. When new, there's a rubber boot on the bolt end, and you're supposed to grease the end where it rides on the stop to eliminate the pop sound. You can either grease the bolt head or the plate stop to eliminate/lessen the sound, or just live with it. Use waterproof grease...
I've never tried to find a new boot, but the dealer may be able to get one.
