Page 1 of 5 1 2 3 4 5
V6 Questions? #914511 11/06/08 04:09 AM
1
1986powerram50 Offline OP
Yo guys tomorrow Im picking up a 1990 V6 Mighty Max 4x4. This isn't my first forte into mitsu 4x4. Though this is my first dealings with the v6's so heres my questions.
1. Any major problems I should be aware of on the V6's i know the valve cover gaskets go bad often and they leak oil any way to remedy that besides changing out the gaskets?
2. I know theres a difference between the V6 monte's and the 4cyl as far as axles and brakes but how about the hubs? I have a set of superwinch manual hubs that came off of my 4cyl truck and am wondering if they would swap over.
3. Cheap/Effective ways to make power out of the 6g72? Any thing? Ive dealt with the g54b's and the 4g64's never the V6's. I do plan on doing an exhaust set up (my inner redneck thinks I need some noise to accompany the truck) What size? Id liek to run duals or as close to duals as I could and figure nice 2.5 would be great your input?
4. Anyone want to pick me up a set of gen2 UCA?? at the yard let me know
--keRby
Ad Inexplorta
Re: V6 Questions? [Re: 1986powerram50] #914512 11/06/08 06:07 AM
Hubs will change over.
I am learning about the V6's too, now parting out 2 4-doors.
Re: V6 Questions? [Re: rxinhed] #914513 11/06/08 05:21 PM
V
vr4 Offline
VSS leak. lifter noise. otherwise the SOHC is nearly bulletbroof.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: V6 Questions? [Re: vr4] #914514 11/06/08 06:41 PM
Hmm, does that imply the DOHC isn't as much? Any thoughts between the 3.0 12V and 24V.
Re: V6 Questions? [Re: 1986powerram50] #914515 11/06/08 11:49 PM
grass13 Offline
stem seals... smoke.
Re: V6 Questions? [Re: MontyMcV] #914516 11/06/08 11:52 PM
KrzyDav Offline
24 valve and 3.5 dohc have a higher H.P. and torque band,,,not as good for crawling.
Valve guides and leaky valve covers and , important!, harmonic balancer bolt and higher torque upgrade.
dave h.
Re: V6 Questions? [Re: KrzyDav] #914517 11/07/08 12:09 AM
<img src="/forums/images/graemlins/zombie.gif" alt="" /> Tell that to CAP510 <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: V6 Questions? [Re: off-roader] #914518 11/07/08 12:38 AM
Most anything from the stock sohc12v 3.0 to the 3.8 will bolt up. I don't think I've ever seen the engine compartment of a gen2 pu. Think you've got room for a turbo on the pside? And I find NO lack of grunt in the 3.5 SR crawling.
I find the idea of a v6 big block pu nice...
Re: V6 Questions? [Re: fasteddy] #914519 11/07/08 12:46 AM
V
vr4 Offline
agreed.
i guess i should state my perception might be slightly skewed regarding the sohc vs. dohc coming from the 3000gt world.
91 MR2 turbo
Re: V6 Questions? [Re: vr4] #914520 11/07/08 01:01 AM
lordtrunks Offline
Check the motor mounts every V6 i've owned they have never been changed and are broken and the only thing holding everthing together is a worn out tranny mount. <img src="/forums/images/graemlins/scared.gif" alt="" />
89 2 dr turbo diesel
89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6450 MB (Peak: 0.7690 MB) Data Comp: Off Server Time: 2026-06-24 14:29:35 UTC
