Page 1 of 4 1 2 3 4
What OEM wheels fit a Gen1 ? #914798 11/08/08 12:14 AM
Pete_D Offline OP
I believe there was a thread showing what other wheels fit the Gen1's. This is for a 90 SWB Monte.
Looking to upsize but would rather find "take offs" from a matching pattern (Tacoma?). I think there were some bolt pattern matches but problems with the center hole sizing.
Does not have to be 15". Who's got the answer?
I edited your title to make it easier for people to know what you were asking about without opening the thread.
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: Wheels ? [Re: Pete_D] #914799 11/08/08 12:56 AM
hazy_daze Offline
I thought most Toys had center bore clearance issues with the rear on our trucks...
Re: Wheels ? [Re: Pete_D] #914800 11/08/08 02:21 AM
Well, Isuzu wheels won't fit!! <img src="/forums/images/graemlins/frown.gif" alt="" /> Not without grinding.
I have mounted (loosely) newer Tundra/Tacoma 16" alloys, but they had 5.5" backspacing, amd why I didn't use them.
Justice had some three-spoke 16" Montero Sport wheels, they'd work. On my Raider, I've had several wheels mounted up...15 inch, various widths, 3.75- and 4-inch backspace. I like the 4"BS best, as even 33x12.5's on a 10 inch rim didn't rub the outside edge of the rear fender well when stuffed. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Wheels ? [Re: Pete_D] #914801 11/08/08 04:59 AM
W
WagonMaster Offline
Funny you should mention that: Just last night I was doing some comparo's.
I don't know what size of wheels these are, or what size of tires came on them, but here's a list of wheels.
Bolt Pattern: 6 x 139.7
Stud Size: 12 x 1.5
Center Bore: 108mm
Offset: Low/Medium
Isuzu:
Amigo '89-'00; Axiom '02-up; Rodeo & Trooper '92-up
Lexus:
LX450 '96-'97
Honda:
Passport '94-'02
The following have a 12 x 1.25 Stud Size, which means getting a different pitch of lug nuts (any auto parts store).
Infinity:
QX4 '96-up
The following have a 106mm Bore, needing a 2mm boreout.
Toyota:
4-Runner '80-'95 & '00-up; Landcruiser '69-'97; Sequoia '01-up; T-100 '93-'96; Tacoma 4x4 '95-up; Tundra '99-up
The following have a 100mm Bore, needing an 8mm boreout.
Chevrolet:
Colorado/Canyon '04-up
Nissan:
Xterra '00-up; Frontier '98-up; Pathfinder '87-'04
Hope this helps.
Wagon Master
HUMMER .25: No need to compensate.
1989 Dodge Raider: 3.0/5
1992 Chrysler LeBaron Convertible: 3.0/A
1994 GMC Safari: 4.3/A
Re: Wheels ? [Re: WagonMaster] #914802 11/08/08 05:13 AM
don Offline
Infinity:
QX4 '96-up
Nissan:
Xterra '00-up; Frontier '98-up; Pathfinder '87-'04; Titan '04-up
Just curious as to how the bolt thread pattern on the studs on these vehicles will effect using the rims on your vehicle. The rims won't know what the bolt thread is...
(good work on the list, though!)
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: Wheels ? [Re: don] #914803 11/08/08 05:54 AM
W
WagonMaster Offline
Don,
No effect at all, I just wanted to be thorough with the information. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Wheels ? [Re: don] #914804 11/08/08 02:30 PM
Unless you could get rims from the likes of QXs and LCs for cheaper than they seem to run, you can get a variety of alloy ones new from Tire Rack for the same as these used ones are in the yards.
Re: Wheels ? [Re: don] #914805 11/08/08 07:17 PM
W
WagonMaster Offline
Well, I screwed the pooch on this one.
As Don pointed out, I didn't think too hard before posting.
The stud info (12 x 1.25) has no effect at all on the wheels or on the mounting, so it shouldn't have been included.
At all.
I try to think things through better before posting in the future. <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
After all, it took the whole night to figure out how I screwed up... <img src="/forums/images/graemlins/shame.gif" alt="" />
Re: Wheels ? [Re: WagonMaster] #914806 11/09/08 06:27 PM
Pete_D Offline OP
Great info - thank you - what I don't see on the list and was wondering about is the later gen Monte wheels - are we all stuck with 15" wheels? If the offset and width are right it seems like that might be an easy answer.
Re: Wheels ? [Re: Pete_D] #914807 11/09/08 08:04 PM
LRJ4x4 Offline
I'm partial to the SR wheels I got from Carlos <img src="/forums/images/graemlins/cheers.gif" alt="" />
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6432 MB (Peak: 0.7689 MB) Data Comp: Off Server Time: 2026-06-22 01:10:54 UTC
