Re: ADD front end swap [Re: grandeyota] #914929 11/11/08 09:52 AM
ldivinag Offline
Does the ADD introduce any mechanical weakness to the axle that is not there in a non-ADD axle? I was not thinking of actuators, vacuum lines, etc., just the actual drive system.
When I had mine apart, the ADD shaft was smaller than the non-ADD unit. I'm thinking the non-add is the stronger setup of the two.
and guess where mine broke?
the axle tapers down. actually, it just shrinks, not actually a gradual taper.
with the ADD out of the way, there are at least 2 links in the chain eliminated.
you also need a new seal.
leo d.
90 4runner, v6, auto, WCOR CitB kit,
marlin duals, arb rear, tt front
4.88, blah, blah, blah...
Pres. of TEAM IFS! and
GETTING OFF 4WD Club member
Re: ADD front end swap [Re: ldivinag] #914930 11/11/08 10:13 PM
ErikB Offline
Toyota Moderator
The axles are 27 spline, the ADD stub is 26 spline, and they do break there sometimes.
As has been mentioned, everything is swappable between the two.
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5955 MB (Peak: 0.6440 MB) Data Comp: Off Server Time: 2026-05-27 21:00:44 UTC
