vibrating/ shaking #915223 11/10/08 02:41 AM
W
wheelin Offline OP
My 89' extended cab toyota 4x4 has a vibration/shaking that begins as vehicle starts to reach speed or so...if i get up to 55mph, then push in the clutch to coast, the vibration stops, so i'm guessing its not the tires...
Any thoughts?
u-joints?...something in the clutch?
Re: vibrating/ shaking [Re: wheelin] #915224 11/10/08 02:55 AM
4Crawler Offline
Might be the rear drive shaft, it'll tip up under load, increasing the angle on the u-joint at the pinion flange. Pushing in the clutch lets it tip back down and possibly run smoother. Some tips on diagnosing the problem on the page below:
- http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml#FixingProblems
Re: vibrating/ shaking [Re: 4Crawler] #915225 11/10/08 07:00 AM
OOP'S Offline
Does it have a two-piece rear D-shaft. If so it could be the center bearing has gone south.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: vibrating/ shaking [Re: wheelin] #915226 11/10/08 08:16 AM
Snowtoy Offline
Do the vibrations come through the bottom of your seat?
If they do, this is also a a sign that the u-joints or center bearing are going south. Definitely something you don't want to put of checking, since it will likely let go at highway speeds when the u-joints/center bearing fails. Before you have the current drive line rebuilt, call a couple of your local drive line shops and see what they will charge to make you a 1pc, it is usually cheaper to have a 1pc made then to rebuild the 2pc oem ones.
PHP: 7.4.33 Page Time: 2.501s Queries: 15 (0.004s) Memory: 0.6027 MB (Peak: 0.6583 MB) Data Comp: Off Server Time: 2026-06-18 05:49:38 UTC
