Page 4 of 4 1 2 3 4
Re: "bent" spring perch [Re: adam] #915509 12/02/08 03:50 PM
Chip Offline OP
Cool! I still have plenty of 1/4" sheet so I'll just get out the cutoff wheel again and start cutting away.
Chip
Re: "bent" spring perch [Re: Chip] #915510 12/02/08 10:34 PM
wsquaredodie Offline
Check out cjm's "so this ones mine" on the old toy truck site . Look at the lift blocks he did.
trafdlo
Re: "bent" spring perch [Re: wsquaredodie] #915511 12/03/08 06:24 AM
Chip Offline OP
Do you know which page in the thread it is? I saw 17 pages of postings. What I read was fascinating.
Chip
Re: "bent" spring perch [Re: Chip] #915512 12/04/08 04:06 PM
Check pics on P7, CJ may have dimensional specs you can use.
trafdlo
Re: "bent" spring perch [Re: wsquaredodie] #915513 12/05/08 06:09 AM
Chip Offline OP
Thanks for the direction. I see them now. That guy's really awesome. Such a huge project and he's doing a great job of it as well as documenting it.
Re: "bent" spring perch [Re: Chip] #915514 12/05/08 05:45 PM
jomentum Offline
blocks are scary...
I removed the 1" blocks that were causing axle wrap
I picked up a set of hummer h3 springs, cut the shackle ends off and added them with my one stock leaf. using 07 tundra u bolts
4" lift , safe, under $200 bucks
www.YotaRanch.com < wrench for hire
Re: "bent" spring perch [Re: jomentum] #915515 12/09/08 11:01 PM
Chip Offline OP
blocks are scary...
That's a nice installation there. Did the H3 springs have the same center offset like the T100's?
I notice that your parking brake cable is rubbing on
the springs. Is that going to be a problem eventually?
I think I'm going to keep going down the Chevy spring path since I'm pretty far down it already.
I got the hangers tack welded in place this weekend and am
waiting for the welder to have some time to come by. It snowed last night so this morning was out. Since he won't be by for a while I think I'll bring the axle in the garage
and patch up the perches with the 1/4" plate like Eric said
earlier.
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6256 MB (Peak: 0.6997 MB) Data Comp: Off Server Time: 2026-06-20 15:32:55 UTC
