Page 2 of 4 1 2 3 4
Re: oops! [Re: DennisThompson] #915691 11/21/08 07:10 PM
logansportage Offline
Dennis,
The Sportage engine is rather tough, so that may have not completely damaged the engine enough to do a complete rebuild. I've had mine boil over a couple times on me this summer due to a radiator that was clogged.
Hopefully just a new head gasket will fix the problem.
Re: oops! [Re: logansportage] #915692 11/22/08 02:54 AM
DennisThompson Offline OP
I just picked the head up from the machine shop, they reserfaced it and fixed 2 leaky intake valves. I am going to put it all back together and hope for the best. If it still don't run I will pull it out and rebuild it, if it runs ok I will try to find a rebuildable engine and build the stroker for a later time.
Wish me luck, Dennis
Re: oops! [Re: DennisThompson] #915693 11/23/08 06:16 PM
fokion Offline
I am exactly at your shoes
my head goew in on Monday...
Re: oops! [Re: fokion] #915694 11/23/08 07:21 PM
That sucks, I know two other people that had them same problem about the same time, 1 Probe, and 1 Accord.
Good luck, Dennis
Re: oops! [Re: DennisThompson] #915695 11/24/08 07:13 PM
Dennis,
Did you get the head put back on? Any update?
Re: oops! [Re: logansportage] #915696 11/25/08 01:23 AM
Not yet, I can't find any allignment dowells for the head. For some reason mine didn't have any when I took it apart. I also destroyed my new YJ radiator. I was cutting off the Jeep mounts to weld on the Kia mounts and the blade in my saw broke and the saw ran down the radiator and cut right through the middle. Yesterday was a very bad day to say the least. After that I just turned the garage light off and went in and watched TV. I will let you know when I get it back together and how it runs.
Dennis
Re: oops! [Re: DennisThompson] #915697 11/25/08 06:35 AM
Everet Offline
bummer...
Re: oops! [Re: DennisThompson] #915698 11/26/08 10:06 PM
Dennis,
I understand the feeling. That's when I get a bigger hammer and go hit the tree next door. My neighbor is beginning to think his tree has a bug or something.
Re: oops! [Re: DennisThompson] #915699 11/27/08 02:04 AM
homerdog Offline
ouch. I had a day like that last week. Went to the hospital because of blood in my urine from some medication I was taking, checked out okay, my ass exploded on the way home, took care of that, hit a deer about 15 minutes later when I was almost home. The only good part was that I rented a car while I was fixing the head gasket on my Sportage so it was the rental car that got smashed by the deer instead of my Sportage. I gave them the $100 deductible and they get to mess with getting it repaired. Here's how my day ended up (2009 Camry).
Re: oops! [Re: homerdog] #915700 11/28/08 05:48 AM
I would much rather have the car problems than the health problems, I hope your ok now. My goal is to have it running tomorrow. I have to do a little wheelin Saturday and I would rather not get the Truck all muddy, Thats what the Kia's for. I have every thing to put it together except the throttle body gasket, I need to make a new one. I found a great place to mount the electric fan thermasat, I will take pics when I do it.
Dennis
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6398 MB (Peak: 0.7640 MB) Data Comp: Off Server Time: 2026-06-21 12:04:49 UTC
