89 3.0 Raider needs ECU and some others #916122 11/16/08 07:50 PM
jrowe Offline OP
I have an 89 3.0 AT Raider with the gray interior. I need an ECU and the connector that attaches to the power unit. I'm also looking for the piece that fits around the shift selector as mine has the tabs broken. Ialso need the storage bin thing that fits in the radio console. I apologize for not knowing the proper names for some of these items.
Re: 89 3.0 Raider needs ECU and some others [Re: jrowe] #916123 11/17/08 04:30 AM
I have the storage bin.
Can you please describe the other piece near your shift selector in greater detail? Are you woring on an automatic or stick Raider?
I do not have the ECU parts, but there has been an 89 in a nearby yard. If it's still there, I'll grab the parts you need.
Russell
Re: 89 3.0 Raider needs ECU and some others [Re: rxinhed] #916124 11/18/08 07:12 AM
jrowe Offline OP
I am working on an Automatic. The piece I'm looking for is the one that has P,R,N,D etc on it. It fits around the shifter. There are two tabs on the front and rear of it and mine are broken so it is loose. If you can get your hands on an ECU I would appreciate it.
Thanks,
Joe
Re: 89 3.0 Raider needs ECU and some others [Re: jrowe] #916125 11/18/08 05:32 PM
CwnAnwyn Offline
If Rx cant get the ECU for you. There was one in a 89 I was just pulling stuff off of this weekend. I could go back and grab it if needed.
Z
Do you think the average stormtrooper knows how to install a toilet main? All they know is killing and white uniforms.
87 Raider TSI
84 K5, 350/700R4,36" TSLs, spooled fr/rr
74 VW Bug- volksrod project
68 VW Fastback, 2L T4 powered
Re: 89 3.0 Raider needs ECU and some others [Re: jrowe] #916126 11/18/08 05:33 PM
OK, I'll check on all the other parts later today.
Re: 89 3.0 Raider needs ECU and some others [Re: CwnAnwyn] #916127 12/02/08 08:30 PM
bearingman Offline
While you guys are checking I need the bolt that holds the harmonic balancer (crank pulley)on for my 89 Montero 3.0. And if the fan clutch is good....?
Re: 89 3.0 Raider needs ECU and some others [Re: bearingman] #916128 12/02/08 09:42 PM
hazy_daze Offline
You don't want that bolt. Go to the Dodge dealer and get P/N's 1101A022 Bolt & MR994412 Washer. Those are the most current iterations of the updated bolt and washer.
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6138 MB (Peak: 0.6912 MB) Data Comp: Off Server Time: 2026-06-09 23:57:44 UTC
