Fuel injector leaking after reassembly
#916202
11/17/08 03:53 AM
I just replaced a head in a 22RE. Now the first fuel injector is leaking from where it joins the fuel rail. Injector 2-4 don't appear to leak. After the fuel pump stopped the injector continued to leak for another couple of minutes. What did I do wrong when I attached the injector into the rail?
---------------------- '87 4Runner
Re: Fuel injector leaking after reassembly
[Re: Chunky]
#916203
11/17/08 05:31 AM
It might be cocked in there. I trust you lubed the o-rings with FUEL, not petroletum? Gotta hold your mouth right when you reinstall these things.
[Re: kewlynx]
#916204
11/17/08 05:59 AM
I didn't lube them at all. Are the o-rings messed up? They came with a new set from RC when I got them cleaned. My gasket kit I got also has some. Should I swap out them o rings or do you think they should still be ok? I pulled them a couple years ago and didn't have a problem, but they must have been still lubed with gas.
[Re: Chunky]
#916205
11/17/08 06:50 AM
By all means, if you've got some new to spare, then swap them out; I would.
[Re: Chunky]
#916206
11/17/08 10:37 AM
No lube is most likely your problem. Mine leaked because I forgot to lube it. FSM calls for a light coat of fuel.
[Re: Adam F]
#916207
11/18/08 05:20 AM
Any more tips. I'm having a hell of time getting this to work. I've taken it off 4 more times. Now I've lubed the seal and replaced them with the new seals. It was the first injector then the fourth then the second then the first agian. What am I doing wrong?
[Re: Chunky]
#916208
11/25/08 03:19 PM
I had this issue with the connectors to the injectors were pulled too tight, the wires and clips were actually pulling the injectors out of whack. Make sure the harness for the injectors lay down nice and easy, you should be good.
