Page 1 of 5 1 2 3 4 5
89 trooper hub wheel bearing problem??? #916223 11/17/08 01:12 PM
rhouser Offline OP
Ok 89 trooper had a problem with the lock nut that goes on the hub nut, and i need to replace the locking nut, first question how does that locking nut keep the hub nut from backing out
2nd questions, doesn anything look wrong when i take this apart? The p.o had this apart before me and im not possitive what it is supposed to look like.
what are all the pin that came out that are in the last pic? is that wheel bearing?
if u see anything in the pic let me know what u see, im so lost here
[Linked Image] [image]
]http://i106.photobucket.com/albums/m254/rhouser30/trooper2.jpg[/image] [image]
]http://i106.photobucket.com/albums/m254/rhouser30/trooper3.jpg[/image]
Re: 89 trooper hub wheel bearing problem??? [Re: rhouser] #916224 11/17/08 01:17 PM
rhouser Offline OP
a couple more
Re: 89 trooper hub wheel bearing problem??? [Re: rhouser] #916225 11/17/08 04:17 PM
Richard Saylor Offline
Those pins are the rollers in the outer bearing. It's toast. You can see all of the metal shavings in there. You'll need new bearings for sure.
Also, it looks like you'll need to replace the disc brake rotor. Looks to me like it's got some nasty grooves in it.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: 89 trooper hub wheel bearing problem??? [Re: rhouser] #916226 11/17/08 04:42 PM
rhouser Offline OP
everything else look ok?
ive got a set of inner and outer wheel bearings coming
Re: 89 trooper hub wheel bearing problem??? [Re: rhouser] #916227 11/17/08 11:08 PM
bamashooter Offline
The bearing sits in the hub.
Next is the hub nut.
Next is the hub nut lock washer.
The knuckle on which you threaded the hub nut has 2 notches.
The lock washer has 2 tabs which sit inside the 2 notches.
The lock washer secures to the hub nut with 3 machine screws (phillip). The nut can not go anywhere now because the washer is screwed to the nut and the assembly is held to the hub/knuckle by the notches and tabs.
Your bottom picture depicts the hub nut and the knuckle on which it is threaded. At about the 12:00 position on the knuckle, you should see a notch. There's one opposite that which is not visible in the photo. The tabs of the lock washer sit inside those notches.
Re: 89 trooper hub wheel bearing problem??? [Re: bamashooter] #916228 11/18/08 01:35 AM
Van Offline
Go to this website... http://www.myisuzuparts.com
Click on your model year, model and underneath "Component Type" click "Illustration Index" and then click "Submit".
Go to page 54 & 55... 'ya just have to keep hitting "next page" until you get to those pages... click on the picture to get a larger picture with part names and #s.
I just figured out a shorter way... just click on the following link and then "Submit" for the "front hub & drum" pic.
http://www.myisuzuparts.com/index.php
O.K., the links are acting up but one of those will get you there.
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: 89 trooper hub wheel bearing problem??? [Re: Van] #916229 11/18/08 03:36 AM
strawmyers Offline
Isuzu Moderator
Did your truck have the hub nut lock washer described above on it? If not, that is likely what led to the failure as it would allow the hub nut to back out and take all of the preload off of the bearings. Not much time after that happens that things go seriously wrong. Take a good look at the bearing surfaces on the inside of the hub as well. If you just put new bearings in a hub that is all marred up, they aren't going to last very long.
Sean Strawmyer
Re: 89 trooper hub wheel bearing problem??? [Re: Van] #916230 11/18/08 03:36 AM
bamashooter Offline
Re: 89 trooper hub wheel bearing problem??? [Re: strawmyers] #916231 11/18/08 03:51 AM
rhouser Offline OP
the races of the bearings are still in the hub i need to get them out, i would guess since they are still pressed in that the surface should be ok right
Re: 89 trooper hub wheel bearing problem??? [Re: bamashooter] #916232 11/18/08 03:53 AM
rhouser Offline OP
hey where did you get this? my hayes manual covers more years so it shows addition parts, just curious where u got it
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6388 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-06-10 09:54:30 UTC
