Page 4 of 5 1 2 3 4 5
Re: 89 trooper hub wheel bearing problem??? [Re: BigSwede] #916253 11/19/08 09:04 PM
rhouser Offline OP
well as of right now i cant find a hub assembly, no junkyard around me has anything that old, and a new one quoted form myisuzu.com is like 450.00. so i guess i will put the old one back on.
Re: 89 trooper hub wheel bearing problem??? [Re: bamashooter] #916254 11/19/08 09:45 PM
Van Offline
I believe 88-91 trooper, rodeo, pickup. Perhaps a late model 87.
Rodeo's won't work... Troopers (4X4) manufactured between 11/1986-07/1991 will work... also pickups (4x4) between 12/1987-07/1991 will fit (hubs).
You can go here to help you find the parts/junk yards close to you or order from them... http://car-part.com/
You could also post up your location and maybe someone close can help you out... there are many other sources, just depends if you want to buy new or used.
HTH
Van <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
'94 Isuzu Pickup, 4x4
NEVER give up...
Re: 89 trooper hub wheel bearing problem??? [Re: bamashooter] #916255 11/19/08 09:59 PM
Van Offline
Just read your last post... [color:"red"]DO NOT PUT THE OLD HUB ON [/color]... as we have all stated, that hub is [color:"red"]NO GOOD [/color]. You are putting yourself and others at risk if you drive it on the road with the old hub. <img src="/forums/images/graemlins/scared.gif" alt="" /> Besides, all the new parts you put on will be wasted as they will were out fast. Is that clear enough for you to understand <img src="/forums/images/graemlins/confused.gif" alt="" />
Not trying to be rude, just trying to help. <img src="/forums/images/graemlins/notooth.gif" alt="" />
HTH
NEVER give up...
Re: 89 trooper hub wheel bearing problem??? [Re: Van] #916256 11/19/08 10:09 PM
rhouser Offline OP
how does the part that is still on the truck that has the splines on it come out of there?
Re: 89 trooper hub wheel bearing problem??? [Re: Van] #916257 11/19/08 10:11 PM
rhouser Offline OP
so my bearing will wear out faster, so i might have to replace them everyear? its a question not a statment
Re: 89 trooper hub wheel bearing problem??? [Re: rhouser] #916258 11/19/08 10:29 PM
Van Offline
There are some "on-line" Trooper manuals that explain the procedure which I (or someone else) will post up later.
The part you're referring to is the CV axle... short story is that it disconnects at the differential.
No telling how long the bearings will last... depends on a lot of different factors.
Also check out... http://www.mwior.com/ ...there more in your neck of the woods... someone might be close enough to help you wrench.
HTH
NEVER give up...
Re: 89 trooper hub wheel bearing problem??? [Re: Van] #916259 11/19/08 10:45 PM
Van Offline
Here is 1 link for a manual (can't vouch as to how good it is)... http://rapidshare.com/files/12885190/Trooper_II_manual.rar
You will need Winrar.exe to open the file.
Hey... I'm not going to do all the work for 'ya. <img src="/forums/images/graemlins/notooth.gif" alt="" />
NEVER give up...
Re: 89 trooper hub wheel bearing problem??? [Re: rhouser] #916260 11/20/08 03:01 AM
strawmyers Offline
Isuzu Moderator
I wouldn't unless dying is on your 'to do' list. <img src="/forums/images/graemlins/scared.gif" alt="" />
One of the guys in our group just picked up a '90 parts Trooper. I'll direct him toward this thread as he might be willing to sell the hub(s) off of it.
Sean Strawmyer
Re: 89 trooper hub wheel bearing problem??? [Re: strawmyers] #916261 11/20/08 05:04 AM
mlclark Offline
Isuzu Moderator
www.car-part.com is your friend.
It is kind of hard to pick just a "hub" out of their list, because I think it sometimes refers the lockout part.
I would start calling places. It is relatively easy for someone to pull the front spindle assembly. Actually, it would be easier than pulling just the hub. Heck, they might even do it with the gas axe and *that* would be even quicker. :-)
There are lots of yards all over the country. The cost for shipping will be steep (the hub is heavy), but just negotiate with these guys. If they give yo flack, or start giving them the run-around, just call the next one on the list. Run even faster if they start trying to charge you for every little nut and bolt. It's not like they have a line of people waiting for these parts.
As for the minimum, you need a hub. The biggest problem is those exposed bolt holes are the ones for the locking hub. Those 6 bolts transfer the torque from the front axle to the hub. They are kind of important. You probably can get a junk yard to send you just the hub and they should be able to help with the interchange of parts.
You could probably get away with a new (used) hub, but you need the lock nut, washer and the guts for the hub too. How you get those, well...that is up to you.
The CV axle is going to be the worst. Isuzu really did not make them easy to remove. You can remove the inner boot and pop the circlip holding in the inner parts of that joint. You will need to probably pop the upper and lower ball joints to get enough room to get the outer end of the axle out of the spindle. It's a dirty and frustrating job.
You can get replacement axles from lots of places. Junk yard, parts store, ect. But, if you do the above method, then you will need to hope/check to make sure the new axle has the same design for the inner joint as your old one.
To get the inner axle out of the rig, you need to pull the front axle housing. Another fun and wonderful job.
This repair is going to take some time and some serious work. If you are not familiar with auto repair, it will be challenging, but not impossible.
Good Luck,
Michael
Re: 89 trooper hub wheel bearing problem??? [Re: mlclark] #916262 11/20/08 01:30 PM
rhouser Offline OP
do i need the CV axle?
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6444 MB (Peak: 0.7566 MB) Data Comp: Off Server Time: 2026-06-18 07:10:18 UTC
