Page 2 of 4 1 2 3 4
Re: SR front end swap? [Re: StockRaider] #916383 11/18/08 02:06 AM
Chris_J Offline
You guys are going to need to clean it up if you want to continue posting here.
Where is the fun in that.
Sorry Sir. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: SR front end swap? [Re: StockRaider] #916384 11/18/08 02:47 AM
justice Offline
As far as being "pushed around" that's probably your imagination, or you need to learn when to turn off the locker.
I almost always leave the locker off until I need it, I am also concerned that it might be the mix of both the Starion front and the SR rear just being too different. Or its the binding of the LSD that has be thinking I'm getting pushed around. [/quote]
I didnt know you have an LSD in the front. Any traction aid in the front can really effect the feel of things..so its probably the cause of what your experiencing...wait till you put in the front locker..nice thing is with the ARB is you can turn it off..
Re: SR front end swap? [Re: justice] #916385 11/18/08 04:18 AM
sparkem Offline
So are you running a 4.636 SR rear axle with the 4.625 front? You should have zero problems with that. My truck works properly.
Re: SR front end swap? [Re: sparkem] #916386 11/18/08 04:32 AM
StockRaider Offline OP
None? hmmm... really must be the front LSD causing all the mischief. I have high hope of getting the blue truck back on the road this winter. I just don't want to take out anymore mailboxes or endanger other drivers with the front end pulling me all over the place.
Anyone want to buy a front LSD? <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: SR front end swap? [Re: StockRaider] #916387 11/18/08 12:12 PM
Y
yankneck696 Offline
Any form of front locker or limited slip will cause a push in the front. You might want to try loosening up the LSD a bit to see if it acts better.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: SR front end swap? [Re: yankneck696] #916388 11/18/08 01:06 PM
A front LSD needs to have little to no preload. It should spin pretty free with no input torque. It will still induce understeer when power is applied though as it locks in.
I need to get a GM 10 bolt diff in my hands to see if I can get it in our trucks. Plenty of Torsen style diffs for them. They are less pushy when in the front axle. Granted they are of little use rock crawling but if the wheels are on the ground they work well.
Re: SR front end swap? [Re: OldColt] #916389 11/20/08 01:04 AM
V
vr4 Offline
ive also contemplated doing a full gen 2 front in my SWB so youre not the only 1. as soon as i can afford the parts ill tackle it.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: SR front end swap? [Re: vr4] #916390 11/20/08 03:16 PM
L
Lee N Offline
Anyone thought of using a Sport front end? Doesn't have the CAD like a Gen II and is also a high pinion design with the same ratios. I think this might be more of a direct bolt in.
Lee
'94 LS, 3.0 V6, Auto, completely stock
Re: SR front end swap? [Re: Lee N] #916391 11/21/08 12:41 AM
sparkem Offline
What is wrong with the 3.0 front axle? There is a locker available. 4.63 and 4.62 difference is so small it does not matter. I think the problem is the LSD in the snow. If you really want to swap, go for it. Just seems like a pain in the <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> to me for no gain.
Re: SR front end swap? [Re: sparkem] #916392 11/21/08 12:50 AM
Since most likely its just the LSD giving me the problems. I will just replace it with the open front I have laying around.
Richard E
1983 Honda XL600R
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6454 MB (Peak: 0.7538 MB) Data Comp: Off Server Time: 2026-05-27 21:23:57 UTC
