no brakelights when headights are on #916544 11/18/08 11:13 PM
G
greenseaman Offline OP
on my 85 4runner I have no brakelights with the headlights on. They work fine with the headlights off... do I have a loose wire somewhere?
Re: no brakelights when headights are on [Re: greenseaman] #916545 11/18/08 11:34 PM
4Crawler Offline
Likely you have a case where the brake light filaments in the 1157 bulb have a missing/bad ground connection a the socket. In this case the filaments can find ground through the parking/running light filaments when they are off. When those lights are on, you then have 12 volts at both sides of the light and no current flows. In that case you would also see that the rear running lights will turn off when you apply the brakes.
Re: no brakelights when headights are on [Re: 4Crawler] #916546 11/19/08 12:10 AM
G
thanks so much, I will try that!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5923 MB (Peak: 0.6454 MB) Data Comp: Off Server Time: 2026-06-22 23:56:29 UTC
