350 wrangler #916729 11/20/08 06:30 AM
Y
yelo4wheeler Offline OP
I recently purchased a 93 wrangler with a chevy 350 and am in need of a lower radiator hose, It has an after market aluminum radiator with outlet on the passenger side as is the outlet on the block does anybody know what vehichle and year I can tell the part store for a hose that will be close to what I need, I know this is a common swap and many will probable be able to help me thank you all
Re: 350 wrangler [Re: yelo4wheeler] #916730 11/20/08 02:26 PM
P
pineymike Offline
You'll have to take the old one and "match it up" with a new one then record the part# some where{on the hood underside with paint marker}if the old one is not good enough just take mesurements make sure the one you find has a spring in side it,This mite not work at a chain type auto parts store try to find a localy owned mom&pop store{almost impossable nowadays}or a speed shop.Good luck have fun! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Re: 350 wrangler [Re: pineymike] #916731 11/20/08 05:09 PM
BigJim Offline
What Mike said times two.
Re: 350 wrangler [Re: BigJim] #916732 11/21/08 06:53 AM
Bigbird79 Offline
I second what the others said, but the logical place to start at the parts house though would be cars that had a small block in them. Maybe a Camaro or something smaller. I am guessing a truck would have a larger radiator than what would fit in a Wrangler, and likely further away too from the engine too.
Sean
99 XJ Sport 2 Door, 4.0L, 5 speed, all stock. Daily Driver
79 F150 Standard Cab Short Box, 400ci, NP435, NP205, 35" SSRs
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5969 MB (Peak: 0.6523 MB) Data Comp: Off Server Time: 2026-06-04 16:55:22 UTC
