OEM Spark Plugs #917185 11/23/08 11:07 PM
T100_4x4 Offline OP
I have been running bosch spark plugs in my 1996 toyota t100 sr5, and am wondering how much of a difference it would make if I put the OEM Denso plugs in it. Sometimes it has more power than it does other times doing the exact same things in the exact same conditions. Does anyone know what the exact Denso plug that came with the truck?
Re: OEM Spark Plugs [Re: T100_4x4] #917186 11/23/08 11:53 PM
stock87 Offline
Denso K16TR11
or
NGK BKR5EKB-11
The FSM usually lists part numbers for both NGK and Denso, since they are the recommended brands. OEM is usually Denso.
Most people on here have found that Toyota engines HATE Bosch plugs. They work fine in german cars, but for whatever reason, the imports do not do well on them.
*EDIT* I'm assuming you have the V6 since you said SR5. Not sure what the 4 banger part numbers are.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: OEM Spark Plugs [Re: T100_4x4] #917187 11/25/08 12:47 PM
E
eleet Offline
I don't know the exact plug number but when I bought them at the dealer the denso plugs were ridiculously cheap.
97 T100 4x4
97 328i
95 540i restoration project
Re: OEM Spark Plugs [Re: eleet] #917188 11/25/08 05:17 PM
Scott Broam Offline
Had the CEL come on while on a road trip - checked the code, needed new plugs. Put some Bosch in from the Advance/AutoZone and it ran terrible. Swapped them out for some Densos at half the price and it ran great...
96 T100 Titan Xcab V6 2WD,Powertrax No-Slip Diff, buckets, mini-mods...
http://picasaweb.google.com/scott.broam/TruckProjects#
Re: OEM Spark Plugs [Re: Scott Broam] #917189 11/27/08 09:31 PM
T100_4x4 Offline OP
I think this might help out a little. The engine puts out 195hp from the factory and i know that my 35's and lift may not help for power but i think im going to order some denso plugs and see how it runs. thanks for the help ill let you all know what happens.
PHP: 7.4.33 Page Time: 1.803s Queries: 15 (1.801s) Memory: 0.6042 MB (Peak: 0.6686 MB) Data Comp: Off Server Time: 2026-10-24 09:46:29 UTC
