I'll give you guys first crack at this: 1986 toyota 4wd.
333,ooo miles. 22r carb. four wheel drive works fine.
the truck starts flawlessly but occasionally the battery seems a little tired. The head was rebuilt three years ago. The transmission was replaced with a used tranny two yrs ago. The truck gets 16 mpg on the highway as I think it's running a little rich. The fuel gauge goes to 1/2 tank.
While sitting parked last year someone T-boned me out of a driveway and smashed the door. That has been replaced with a used door but the B pillar below the body crease has a major dent and the door has to be closed firmly to latch.
There are two new fenders installed, they've been painted a fresh coat of red along with the hood. New front bumper. The box is off a '84 2wd (japan lip)and has some areas of surface rust and small dings but is generally in OK shape. There's a hole in the frame near the gas tank about the size of my fist. The frame tube cross member where the muffler hangs is pretty much gone. There's a pretty good oil leak from the engine I think at the distributer or head gasket and I add oil about once a month. New alternater. New pass. side tie rod end.
The transmission detent in first occasionally wants to slip out of gear at stop lights so I just shift into 1st on green or I hold the shifter.
Alloy wheels with 10 x 31 bf goodrich shoes. Decent tread left.
The heater tube leaks at the firewall and needs to be patched or replaced. I have the hose piched off with a clamp. The passenger side door handle is seized an has to be opened from the inside with a snick of a screwdriver. The windshield leaks a little.
I understand that the description seems rough but I would drive this truck anywhere right now. I'll get some pictures taken tomorrow.
I can e mail them to you. DE13323@yahoo.com
$900 Truck is located 20 miles east of Buffalo, NY
Edit: New rear brakes and rear axle seals 1 year ago
