Compatible Engines for Gen II #917540 11/25/08 09:53 PM
G
Guntero Offline OP
Sadly, it seems as if my Guntero has a substantial oil leak. After much dripped oil and a professional diagnosis, it has been determined that the valve seals are gone as well as the gaskets. After 275k + lovely miles, i beleive its time (and have been advised) to do an engine swap.
Which engines are perfectly compatible with my 1995 LS? And what would be the best of these to drop into my Guntero?
Thanks
Guntero (died in battle)
1995 Montero LS - Matte Black
265/75R16 BFG All-Terrains
Guntero (current)
2001 Montero Limited - Gold
OME HD Lift
285/75R16 BFG All-Terrains
Re: Compatible Engines for Gen II [Re: Guntero] #917541 11/26/08 06:44 AM
Why not just rebuild the one you have, or get another Monty 3.0 24V? Nothing is "perfectly compatible," though there are other possibilities.
Start with a search on this one, as it comes up on a quarterly basis. Especially look at posts by FrankR and OldColt.
Re: Compatible Engines for Gen II [Re: Guntero] #917542 11/26/08 07:31 AM
justice Offline
Thanks
24V SOHC 6G72
Re: Compatible Engines for Gen II [Re: justice] #917543 11/26/08 05:30 PM
But doesn't "perfectly compatuble" have to be defined in terms of needs? As in, Diamante engine is not the exact same as a Montero. It can go in, and very well might be worth having in. But it depends on the needs.
Similarly, some variations could need some form of "fitment" to make them work. Maybe nothing much, but not necesarily plug-and-play like a Montero engine.
Disclaimer: This is all based on my memory of past threads, and not on any factual first hand knowledge. <img src="/forums/images/graemlins/lol.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6045 MB (Peak: 0.6603 MB) Data Comp: Off Server Time: 2026-06-07 11:10:20 UTC
