C223TD oil pressure
#918192
12/01/08 08:40 PM
Folks- What's your oil pressure in your Trooper 2.3 TD? At 2500 rpm mine is about 56 psi with the engine fully warmed. I use 15w-40 and have driven about 2000 miles since it was last changed. Just curious if this is normal.
Steve
Re: C223TD oil pressure
[Re: Steve in VA]
#918193
12/02/08 01:51 AM
Folks- What's your oil pressure in your Trooper 2.3 TD? At 2500 rpm mine is about 56 psi with the engine fully warmed. I use 15w-40 and have driven about 2000 miles since it was last changed. Just curious if this is normal. PERFECTLY NORMAL AT THAT RPM, AT IDEL IT MAY DROP DOWN TO 10-20 PSI AND IS NOTHING TOO WORRY ABOUT. 50-60 PSI AT ANY RPM IS MORE THAN ENOUGH FOR THAT ENG. JERRY
PHP: 7.4.33 Page Time: 5.268s Queries: 15 (0.003s) Memory: 0.5864 MB (Peak: 0.6341 MB) Data Comp: Off Server Time: 2026-06-22 14:53:35 UTCValid HTML 5 and Valid CSS
