Page 1 of 3 1 2 3
DOHC head interchange question #918624 12/03/08 06:38 AM
justice Offline OP
I want to confirm weather or not the 3.0 DOHC and 3.5 DOHC heads are interchangeable. I've heard that they are the same but not sure if it's been done. There are plenty of DOHC Diamantes at the yards here. I would like to pull a set and get them spiffied up for my SR if they will fit. That way I can keep my SR running untill the heads are ready and then swap them in in a weekend. I'm sure OldColt or VR4 knows <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: DOHC head interchange question [Re: justice] #918625 12/03/08 03:01 PM
Yes the castings are the same. You do need to watch for early and late heads though. Before 93 they did not have the bosses for the cam sensor on the front of the head.
Re: DOHC head interchange question [Re: OldColt] #918626 12/03/08 03:38 PM
justice Offline OP
OK, So swapping over cams and cam sprockets and I should be good to go. Thanks
Re: DOHC head interchange question [Re: justice] #918627 12/03/08 04:05 PM
Mad_Scientist Offline
I've been thinking about this very idea for a while now since I suspect my valve guide seals are leaky (might be PCV though). What other vehicles got the 3.5L SOHC engine?
Sorry for the hijack <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: DOHC head interchange question [Re: Mad_Scientist] #918628 12/03/08 05:43 PM
V
vr4 Offline
93+ DOHC 3000gt, stealth, and diamante will all work....though you may want to double check the water crossover bolt locations. if you somehow find a twin turbo the ports flow much better. itll be similar to having ported heads on your truck.
3.5 SOHC was found in diamantes 97+ not sure what else.
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: DOHC head interchange question [Re: vr4] #918629 12/03/08 06:04 PM
justice Offline OP
The water crossover pipe is what concerns me a little. But The Diamante DOHCs are plentifull in the yards here and easier to find than a DOHC Montero. Also are the left and right banks interchangable on the DOHC engines? Since I'm lazy, It would be easier to pull two different front heads off two seperate cars maybe not the best idea, but a thought...
Re: DOHC head interchange question [Re: justice] #918630 12/03/08 07:34 PM
V
vr4 Offline
IIRC they are the same casting front and rear but with different bosses drilled etc.
no matter how you look at it you will need a rear head for the cam sensor mount. ill check my early DOHC heads when i get home to double check that theyre the same front and rear.
FWIW its pretty easy to pull the rear head out of a diamante. i havent done it in a yard but it could likely be done in about 90 minutes since you can just cut the belts instead of take everything down to the bare block properly. it took me 2 hours to pull an SR engine out of the yard since i wasnt going to be reinstalling it.
91 MR2 turbo
Re: DOHC head interchange question [Re: justice] #918631 12/03/08 09:17 PM
FrankR Offline
If you pull the heads off of 2 engines, be sure to measure the head thickness so you don't have one that has been milled and another that has not.
Frank
Re: DOHC head interchange question [Re: FrankR] #918632 12/03/08 09:29 PM
justice Offline OP
You read my mind Frank I was just thinking about that. I think it would be wise to just pull from 1 engine.
Re: DOHC head interchange question [Re: justice] #918633 12/11/08 02:56 AM
I
IncorpoRatedX Offline
Not at all, you'd have the ports backwards...
pull two 'front' heats and you'll have two passenger side heads which would put the exhaust ports on the inside on the driverside... <img src="/forums/images/graemlins/scared.gif" alt="" />
V45W - 1999, 3.5 sohc, winter package
L042G- 1987, 2.6 carb, auto - Cylon Raider
A112 - 1973 Galant Wagon - 4G63 Turbo, 5 speed
L023G - 1983, 2.6 carb, 5 speed manual 4WD
L028 - 1983, 4D55 turbo diesel 2WD
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.013s Queries: 16 (0.010s) Memory: 0.6458 MB (Peak: 0.7697 MB) Data Comp: Off Server Time: 2026-07-15 12:25:47 UTC
