Page 3 of 3 1 2 3
Re: DOHC head interchange question [Re: vr4] #918644 12/18/08 08:21 PM
Hans_GZP Offline
I'm going to check tomorrow on a set of 3kGT twin turbo heads, if swapped how you've explained, the heads externally look like they'll work, but im going to have to check out the cam situation.
I'll post info as i find out, unless you've actually done this or have a set of DOHC heads.
93+ 3000GT/Stealth heads are interchangeable with SR heads. They are identical and can be swapped from side to side (just spin them 180 degrees and swap locations for the coolant block off plate). The castings are the same and so are all of the mounting holes.
who let you in hans?
<img src="/forums/images/graemlins/smile.gif" alt="" />
I've been here longer then you!!!!!!! I finally built an engine for my SR. Now I found a cleaner one with a lot less miles on it with a blown engine.... and it's not green!!! I should be getting that this weekend and tossing the engine in so I can drive it on monday.
Re: DOHC head interchange question [Re: Hans_GZP] #918645 12/18/08 08:52 PM
V
vr4 Offline
about damn time. <img src="/forums/images/graemlins/lol.gif" alt="" />
i have another 95 74 sitting in my driveway. snagged it from a pick n pull. all manifolds and a brand new butterfly assy. smile
now the questions is...who completes the TT first? i got mine running first..... <img src="/forums/images/graemlins/cheers.gif" alt="" />
87 Montero V6 SWB auto. dual bouncies
89 Montero V6 SWB 5 speed. dual bouncies
97 3000gt VR4 upgraded turbos, 10:1, E85
91 Stealth TT twin 18Gs, cams/heads, E85
03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" />
91 MR2 turbo
Re: DOHC head interchange question [Re: vr4] #918646 12/18/08 09:22 PM
Hans_GZP Offline
[quote]I'm going to check tomorrow on a set of 3kGT twin turbo heads, if swapped how you've explained, the heads externally look like they'll work, but im going to have to check out the cam situation.
now the questions is...who completes the TT first? i got mine running first..... <img src="/forums/images/graemlins/cheers.gif" alt="" /> [/quote]
I was thinking of a rear mounted turbo since the engine bay is kinda crammed.
I grabbed a 74 from a junkyard down in texas. We had two sr's here at a local pick and pull but the engines were gone the same day they hit the yard. They grabbed a lot of the interior on them too... I was pissed. I figured having 2 SR's would be ideal. Then I can lift on and have it for offroad duty and I can turbo the other and use it on the streets smile
96 Montero SR
94 Dodge Stealth TT
92 Mitsu Galant VR4
91 Mitsu 3000GT
95 Mitsu 3000GT, carbon black, for sale
95 Mitsu 3000GT, white, for sale
92 Mitsu 3000GT VR4, silver, for sale
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6071 MB (Peak: 0.6792 MB) Data Comp: Off Server Time: 2026-07-16 03:40:22 UTC
