Cab steps...... #919230 12/06/08 08:37 PM
masheen Offline OP
My truck is raised 8" over stock. Finding anything in the way of steps for an older Toyota truck is about impossible. I want to bolt a side step to the frame (not the rocker panel) which will allow easier entry/exit from the truck. Ideally, a drop of 6-8" would be perfect.
I'm not interested in nerf bars because all of them appear to come out straight from the frame and wouldn't give as much of a drop I'm after. Plus, there just doesn't seem to be any made for the older Toyota's before 99.
Had my eye on a set of Kodiak Sidewinder retractable steps but I'm not sure they'll fit an 85. I called these guys up and they weren't much help in knowing if these would work. I like them because they drop 8" when the door is opened and retract when it is closed. Here's a link to their site:
http://www.kodiaksidewinder.com/
So, would you guys and gals mind sharing your experience and knowledge in assisting me in this search for a set of steps for my truck. I know too many short people who have problems getting into my truck and I'm tearing the crotch outta all of my Levi's from the spread!!
Thanks much!
85 4x4,22r Carb, BFG 33x12.5/15x10 Rocket Startrack rims, 2" Body Lift, Rancho Springs(3"f/2"r), stabilizer & adj tork rod, Skyjacker adj drag link ,Bilstein shox, Line-x'd where it counts, KC HiLites, grill guard, roll bar, dual quad rear bumper.
Re: Cab steps...... [Re: masheen] #919231 12/07/08 12:05 AM
Adam F Offline
You would probably have to make your own brackets to make any of those steps work. But they should work.
97 4R, stock, daily driver
Re: Cab steps...... [Re: masheen] #919232 12/07/08 02:31 AM
missouriman Offline
well if you wheel..
I would do a set of rock sliders.
one friend has a drop bracket that he stores in the truck.
pulls it up with a rope.
a second guy has a horse saddle sturip with the leather strap he lets hang.
Re: Cab steps...... [Re: missouriman] #919233 12/07/08 02:35 AM
4Crawler Offline
One guy put a bolt-on step on a set of my rock sliders:
Held on w/ 2 bolts and when he went off-road, they were easily unbolted.
Re: Cab steps...... [Re: masheen] #919234 12/08/08 09:14 AM
Snowtoy Offline
If you wheel at all, those kodiaks would likely get ripped right off.
I would start with a set of rock sliders and have a hoop fab'd up the length that you need. I would then notch the outside rail of the slider to the rear of the door, and install the hoop there. When the hoop was in its up position it would fill in the space cut out of the slider. I would make a quick release spring pin that when pulled allowed you to lower the hoop and lock it into place using the same spring, then once in the truck reach back pull the pin the hoop would move back into the up position via a spring, and the pin would lock the hoop in place.
The drawing isn't the greatest(don't have a good drawing program), but something along the lines of this.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6076 MB (Peak: 0.6887 MB) Data Comp: Off Server Time: 2026-07-14 04:19:00 UTC
