Rear locker
#920498
12/14/08 04:23 AM
Any one know how to lock the rear locker with out putting it in 4wd. Its got to be a wire you can cut. I just don't know what one.
92 Galant vr4 11.17at132mph 98 Montero 2.5"lift,33/10.50/15,15x8procomp wheels. trail-gear rock sliders,ARB front bumper,Warn m8000 winch. Piaa lights.
Re: Rear locker
[Re: Brianawd]
#920499
12/14/08 04:28 AM
run a wire from a switch to your pump which is under the rear bench seat. I have mine on my 89 Montero able to lock at any time. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
Re: Rear locker
[Re: Brianawd]
#920500
12/14/08 05:23 AM
Find the locker control module. Snip the brown wire and ground it.
'06 Dakota QC 4.7 6sp 4x4 '88 Mighty Max '77 KZ1000 fun old bike
Re: Rear locker
[Re: NathanC]
#920501
12/14/08 07:48 AM
Find the locker control module. Snip the brown wire and ground it. NateC swings in with a quick, and correct answer. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Rear locker
[Re: NathanC]
#920502
12/15/08 04:02 AM
Find the locker control module. Snip the brown wire and ground it. Where is it located in the cab. Drive or passenger foot well?
Re: Rear locker
[Re: Brianawd]
#920503
12/15/08 05:02 AM
LH rear cargo area. Above the wheel well.
Re: Rear locker
[Re: NathanC]
#920504
12/15/08 06:39 AM
LH rear cargo area. Above the wheel well. Thank you
Re: Rear locker
[Re: Brianawd]
#920505
12/15/08 03:52 PM
There is a second module back there, depending on how equipped. (I think the other is the adjustbale ride?) Make sure you get the right one. Pretty sure the locker is above the wheel well itself, and more forward, where the other module is rearward and closer to there the work light sits. Of course if the other one doesn't have a brown wire, you're in safer shape... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: Rear locker
[Re: NathanC]
#920506
12/15/08 06:07 PM
Find the locker control module. Snip the brown wire and ground it. thank you. i was wondering the same thing.
87 Montero V6 SWB auto. dual bouncies 89 Montero V6 SWB 5 speed. dual bouncies 97 3000gt VR4 upgraded turbos, 10:1, E85 91 Stealth TT twin 18Gs, cams/heads, E85 03 cobra lightly modded <img src="/forums/images/graemlins/lol.gif" alt="" /> 91 MR2 turbo
Re: Rear locker
[Re: vr4]
#920507
12/15/08 06:49 PM
I sort of remember a post about how to rewire the activetrac so all the selections were manual, like center diff lock and rear lock. Sure would like to see that one again...
