Page 1 of 3 1 2 3
my monty died on the interstate #920532 12/14/08 11:24 AM
91monterov6 Offline OP
i was driving on i79 in morgantown wv about 100 miles from home and all of a sudden she quit. there was no jerking or sputtering she just shut off, after sitting on the side of the road for 5 hours in 18* weather and nobody stopping to see if i was ok even though i had my flashers on and wrote help on the back of my monty. well finally my cousin came and said the fuel pump didnt sound like it was getting power or was bad so we replaced it.
after replacing it it still wouldnt start and when we checked for spark from the coil there was none.
besides replacing the coil what else should i check?
Re: my monty died on the interstate [Re: 91monterov6] #920533 12/14/08 11:32 AM
StockRaider Offline
My Raider did the SAME THING. Check your ECU, I found that my windshield leaked onto the ECU causing the connections to become too corroded. If you have a spare swap them out.
Check there first and report back.
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: my monty died on the interstate [Re: StockRaider] #920534 12/14/08 11:51 AM
ive been trying to find a spare ecu, but ive always been broke lol, guess ill have to buy one.
Re: my monty died on the interstate [Re: 91monterov6] #920535 12/14/08 02:25 PM
anyone got a working ecu i can borrow to test with? ill ship back when done
Re: my monty died on the interstate [Re: 91monterov6] #920536 12/14/08 02:42 PM
sasnydley Offline
Timing belt break?
Re: my monty died on the interstate [Re: sasnydley] #920537 12/14/08 03:17 PM
would the tbelt breaking cause no spark at the coil?
Re: my monty died on the interstate [Re: 91monterov6] #920538 12/14/08 03:48 PM
sparkem Offline
That stupid little black box next to the coil will stop spark. There is also a sensor in the dizzy that will stop spark. Did you try the fuel pump tester plug to power it, or just turn the key? I dont think it runs if you just turn the key. If it is a broken timing belt, it will sound weird when spinning just the bottom of the engine over. The ECU will also just die with no warning. It should give you a check engine code though. Did you check those?
Re: my monty died on the interstate [Re: sparkem] #920539 12/14/08 05:07 PM
we tested the pump while cranking, what is the lil black sob by the coil called incase i hava to go to AZ or napa
Re: my monty died on the interstate [Re: 91monterov6] #920540 12/14/08 09:52 PM
hazy_daze Offline
NAPA P/N TP125 Ignition Control Module.
You need to take out the ECU first and smell for nasty fish, which means mushroomed caps. That's the first place to start...
Re: my monty died on the interstate [Re: hazy_daze] #920541 12/14/08 10:50 PM
ecu is clean, immaculate, lookslike new
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6387 MB (Peak: 0.7451 MB) Data Comp: Off Server Time: 2026-05-31 16:52:33 UTC
