Page 3 of 3 1 2 3
Re: Pre 3.4 Swap Questions [Re: kewlynx] #921547 12/24/08 10:51 PM
yotaman7 Offline OP
So basically, when you get the harness, you have to get all the sensors from it. You can get a 96-04 harness, but you have to get EVERY sensor with it to make it work right, and just use what you have now as a long block.
Good luck.
That is my plan, just use my current engine now as a long block since i know its in good condition. I'll take everyother part from the donor. Thanks!
Sorry if we're goin' a little off track, Yotaman!!
hey no problem, good info here.
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: Pre 3.4 Swap Questions [Re: CJM] #921548 12/24/08 11:29 PM
yodta Offline
this is also what happens when you park in a bad neighborhood overnight.
i'm building my own... using the original wiring from the donar.. EWD's for both trucks, and some patience.
msg - '87 xtracab
Re: Pre 3.4 Swap Questions [Re: yodta] #921549 03/02/09 02:52 AM
Snowtoy Offline
according to a member over on Marlin, the wiring is only 4-5 wires and can all be done under the dash. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Seeing what the ORS harness cost initially and just last year, as well as what CJM and others in the past have done, he is either a wiring genius or completely full of BS.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 1.409s Queries: 16 (0.006s) Memory: 0.6008 MB (Peak: 0.6706 MB) Data Comp: Off Server Time: 2026-11-02 07:39:53 UTC
