Re: 4 wheel drive in making rubbing noise & the shop is lost!
[Re: logansportage]
#921634
12/24/08 01:28 AM
Thanks gonna give it a whirl tomorrow and see what's up with it......What about an inner bearing????? Could that be it also? And how would i get to that? Thanks for all your help.
[2001 Kia Sportage- Mommy's Soccer Van]
2001 Tan Kia Sportage, has a K&N air filter, Warn Hubs but there's nothing really special about it, but my 7 year old loves my KIA cuz she sits up high!
[Re: kellbell77]
#921635
12/24/08 01:36 AM
It could be the problem. I'll have to review the manual for doing the inner one. Haven't done mine yet, but need to.
[Re: logansportage]
#921636
12/24/08 02:48 AM
That would be super! Since it's off, might as well do them both. Cuz if i change one, more then likely the other will take a dump.......
I appreciate all your help. I try to do al my own labor on my vehicles, cuz i don't have the money to do it. and i can't find a manual for this stupid car and relied on Axeman helping me last year on the head gasket repair. Saved me alot of money.
Thank you again!
[Re: DennisThompson]
#921637
12/28/08 02:16 AM
Ok replaced the outer bearing and still the noise, however, the sound is quieter, but now feel a slight vibration on the floor board. Someone mentioned slip joints? Where are they? How do i get to them? Single mom, trying to do this on my own. Any help would be very grateful. Thank you
[Re: kellbell77]
#921638
12/30/08 04:28 AM
ok, checked the whole undercarriage, greased the nipple for the slip joint, it's not rusted at all and still makes the noise. Now what?
[Re: kellbell77]
#921639
12/30/08 02:24 PM
If you can, remove the front drive-shaft and make sure the slip-joint is working and at the same time check the U-joints and make sure they are not the problem. The drive shaft is not difficult to remove since it is mounted with flanges.
2009 Sorento LX, 4x4, V6, Auto, Red
[Re: Airdale73013]
#921640
01/05/09 10:51 PM
If you do this, just make sure you draw a mark across both pieces so when you put them back together they line up correctly again.
This keeps the drive line from wobbling and runs just like you didn't pull it apart.
If not, it will start vibrating at a specific speed and you will have to unbolt it again and again clocking it by 90 degrees each time until you find the proper alignment.
[Re: logansportage]
#921641
01/06/09 06:50 AM
she had the half shaft replaced,
2001 5sp. K&N stock filter 215/70/15 If your check engine light is on at least you know the light still works
[Re: bombardj1]
#921642
01/09/09 02:47 AM
Thanks a bunch bombardj for catching my back on that....
[Re: kellbell77]
#921643
01/13/09 09:17 PM
Haven't been on for a while, and just got your PM. Good to hear you are back on the road. Sorry to hear that it was the half shaft.
If you replace your muffler, depending on how many miles you have, you might want to do a complete Cat Back replacement with a high flow Cat and Muffler. Also increase the pipe diameter to 2.25". This will wake up the engine and get you more power.
