Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: logansportage] #921634 12/24/08 01:28 AM
kellbell77 Offline OP
Thanks gonna give it a whirl tomorrow and see what's up with it......What about an inner bearing????? Could that be it also? And how would i get to that? Thanks for all your help.
[2001 Kia Sportage- Mommy's Soccer Van]
2001 Tan Kia Sportage, has a K&N air filter, Warn Hubs but there's nothing really special about it, but my 7 year old loves my KIA cuz she sits up high!
Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: kellbell77] #921635 12/24/08 01:36 AM
logansportage Offline
It could be the problem. I'll have to review the manual for doing the inner one. Haven't done mine yet, but need to.
Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: logansportage] #921636 12/24/08 02:48 AM
That would be super! Since it's off, might as well do them both. Cuz if i change one, more then likely the other will take a dump.......
I appreciate all your help. I try to do al my own labor on my vehicles, cuz i don't have the money to do it. and i can't find a manual for this stupid car and relied on Axeman helping me last year on the head gasket repair. Saved me alot of money.
Thank you again!
Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: DennisThompson] #921637 12/28/08 02:16 AM
Ok replaced the outer bearing and still the noise, however, the sound is quieter, but now feel a slight vibration on the floor board. Someone mentioned slip joints? Where are they? How do i get to them?
Single mom, trying to do this on my own. Any help would be very grateful. Thank you
Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: kellbell77] #921638 12/30/08 04:28 AM
ok, checked the whole undercarriage, greased the nipple for the slip joint, it's not rusted at all and still makes the noise. Now what?
Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: kellbell77] #921639 12/30/08 02:24 PM
A
Airdale73013 Offline
If you can, remove the front drive-shaft and make sure the slip-joint is working and at the same time check the U-joints and make sure they are not the problem. The drive shaft is not difficult to remove since it is mounted with flanges.
2009 Sorento LX, 4x4, V6, Auto, Red
Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: Airdale73013] #921640 01/05/09 10:51 PM
If you do this, just make sure you draw a mark across both pieces so when you put them back together they line up correctly again.
This keeps the drive line from wobbling and runs just like you didn't pull it apart.
If not, it will start vibrating at a specific speed and you will have to unbolt it again and again clocking it by 90 degrees each time until you find the proper alignment.
Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: logansportage] #921641 01/06/09 06:50 AM
bombardj1 Offline
she had the half shaft replaced,
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: bombardj1] #921642 01/09/09 02:47 AM
Thanks a bunch bombardj for catching my back on that....
Re: 4 wheel drive in making rubbing noise & the shop is lost! [Re: kellbell77] #921643 01/13/09 09:17 PM
Haven't been on for a while, and just got your PM. Good to hear you are back on the road. Sorry to hear that it was the half shaft.
If you replace your muffler, depending on how many miles you have, you might want to do a complete Cat Back replacement with a high flow Cat and Muffler. Also increase the pipe diameter to 2.25". This will wake up the engine and get you more power.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.004s) Memory: 0.6366 MB (Peak: 0.7443 MB) Data Comp: Off Server Time: 2026-06-17 10:30:19 UTC
