Re: Now another thing [Re: yotaman7] #921832 12/23/08 05:45 AM
kewlynx Offline
Not on my '86; I trust you're referring to the panel bulbs, yes?
**ubi apis- ibi salus**
Re: Now another thing [Re: kewlynx] #921833 12/23/08 05:50 AM
yotaman7 Offline
I remeber some vehicle I worked on that when a tailight was out it would turn on the brake light but i doubt our older models have that feature. Maybe i'm thinkin of my moms highlander?
"4X4 in upper case is $X$" Quoted from http://4crawler.com/4Runner.shtml
'00 tacoma 4WD---Sold to Toyota
'93 pickup 2WD
'85 pickup 4WD
Re: Now another thing [Re: yotaman7] #921834 12/23/08 06:21 AM
kewlynx Offline
You might; take a look at her owner's manual.
Re: Now another thing [Re: kewlynx] #921835 12/23/08 02:43 PM
G
Greg_Canada Offline
IS there a problem with the e-brake switch? Go under the dash and press it in to check.
89 4Runner
Re: Now another thing [Re: Greg_Canada] #921836 01/05/09 01:17 AM
Tcloud Offline OP
Well thanks for all the help. We are now in AZ and its still on. I tow this truck behind a motorhome when we go on trips. The truck had new brakes on the rear new pads on the front and the mastercylender is full.
I just don,t now what else to check.
Thanks Don
Re: Now another thing [Re: Tcloud] #921837 01/17/09 05:20 PM
Stevie Offline
My money's on the e-brake switch/circuit.
'80 4X4 Longbed
Re: Now another thing [Re: Stevie] #921838 01/17/09 05:26 PM
Adam F Offline
dude, did you check the ebrake switch yet?
97 4R, stock, daily driver
Re: Now another thing [Re: Adam F] #921839 01/19/09 08:11 PM
rovers1973 Offline
I've had this problem on my 91 for a while now. Light stays on dimly ever after the e-brake is off. There is a definite change in the brightness with it on and off. Every once in a while the light will go off completely too. I have replaced the pads and the rotors, and put in a new m/c but it didn't change. I was told it could be the sensor in the resovoir cap but I haven't got around to changing it.
91 SR5 Xtra Cab, 298000km, 4" lift, 56" rear springs, 33-12.5R15 BFG Mud-Terran T/A KM2.....and an '85 axle still waiting to go in.
Re: Now another thing [Re: rovers1973] #921840 01/20/09 09:57 PM
yota4runna Offline
That shouldn't be too tough to check. Just unplug the reservoir cap wire and see if it goes off.
Re: Now another thing [Re: yota4runna] #921841 01/21/09 05:06 PM
Tcloud Offline OP
Thanks Guys it was the brake light switch. If I push it in it will go off. When I put the brake handel in the tang that pushes the switch in has to be just right. It wants to slide of to she side of the switch.
Thanks
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6366 MB (Peak: 0.7441 MB) Data Comp: Off Server Time: 2026-06-23 00:42:36 UTC
