need to replace caliper #922120 12/23/08 03:37 PM
catman25 Offline OP
i got one that is grinding and its like real heavy snow here so i wanted to take it off and just put one set of calipers on just till a nice day . Any tips on getting bolt out with out breaking them ? i broke one before and if it breaks them im done for , No money and parts yard is shut down till spring .
check out my truck and please sign my guest book *CHECK OUT MY RIDE*
Re: need to replace caliper [Re: catman25] #922121 12/23/08 09:16 PM
bombardj1 Offline
I would replace both side at the same time, use some PB Blaster on the bolts and let them sit over night, I would not just throw on used ones. do you know it is the caliper ? are the pads worn down all the way ? how are the rotors ? do you live in the USA ? I know you said there is no money, if the pads are worn down I would throw on a set then save up for loaded cal's and maybe rotors.
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: need to replace caliper [Re: bombardj1] #922122 12/23/08 10:28 PM
catman25 Offline OP
i need to get by till nicer weather , thought pads could make it but guess not , been rough times latly , looking just to throw a pad on till better weather and hope other side last a while . by the time i get home its 6 and dark and cold and i cant drive metal to metal <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: need to replace caliper [Re: catman25] #922123 12/23/08 11:27 PM
bombardj1 Offline
I need to do a oil change and the cold is a biggy for me I have nerve damage in my hands and any cold my fingers go numb and hurt so bad I have to run hot water over them, maybe this Sat. they say it should be warmer, I know a lot of guys here get it colder but my body just can not take the cold anymore.
Re: need to replace caliper [Re: bombardj1] #922124 12/24/08 03:50 AM
Everet Offline
PB Blaster can be your friend...
Where do you live? Kragen/O'Riley's has front pads for $20.00.
PM me and I'll see what I can do to help you.
Everet
Re: need to replace caliper [Re: Everet] #922125 12/24/08 05:52 PM
Everet Offline
Catman...check your pm. Get back to me quick!!!
Everet
Re: need to replace caliper [Re: Everet] #922126 12/26/08 03:16 PM
Everet Offline
Catman...pm me with your phone number...I have something for you.
Everet
Re: need to replace caliper [Re: Everet] #922127 12/26/08 03:26 PM
catman25 Offline OP
sry havent been on , got brakes off.. fuuuuuking slider bolt broke in the harness , trying to find a place that sells those <img src="/forums/images/graemlins/frown.gif" alt="" /> need to drill old one out <img src="/forums/images/graemlins/frown.gif" alt="" /> thanks for the pm ... Any one know of a compatible slider bolt from another vehichle ?
Re: need to replace caliper [Re: catman25] #922128 12/30/08 07:09 PM
Everet Offline
Catman,
Check your PM's again.
I left you one with my phone number.
Call me if you want, but get back to me so you can pick up your Christmas present.
Everet <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: need to replace caliper [Re: Everet] #922129 12/30/08 09:29 PM
catman25 Offline OP
u r a saint . ill grab your number and give ya a call . send me a pm . I just sent you one .
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6337 MB (Peak: 0.7369 MB) Data Comp: Off Server Time: 2026-11-03 09:20:59 UTC
